Old 09-07-2007, 10:22 PM   #1
jorgensensc
jorgensensc's Avatar
Repro '67 shift indicator?
Do they make a repro '67 automatic NON tilt column shift indicator? The housing on mine was broken then fell off and I stepped on it. I'm not talking about the PRNDL housing, but the actual pointer housing that screws to the column. I need to get another, do they repro this item?
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 09-07-2007, 10:37 PM   #2
Tim Christian
Tim Christian's Avatar
Re: Repro '67 shift indicator?
No Shawn all they reproduce is 71-72 style in non tilt.
Tim Christian is offline   Reply With Quote
Old 09-07-2007, 10:38 PM   #3
jorgensensc
Thanks Tim!
Old 09-08-2007, 10:23 AM   #4
69GMCor70Chevy
69GMCor70Chevy's Avatar
Any way this will bolt to a 70? Mine is cracked, it works fine, but I would like to replace if possible.
68 Camaro - 327 Original Red on Red Car
69 GMC LWB - Built 350 a Blast To Drive
69 GMC LWB - "Green Machine" One Family Truck
70 Mercury Marauder - Future Project
69GMCor70Chevy is offline   Reply With Quote
Old 09-08-2007, 10:58 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
yep, it'll bolt on, you'll want the pointer too.
Or become a subscribed member and post a WTB on the correct set up.
