Old 09-29-2002, 07:52 PM   #1
doc70sub
doc70sub's Avatar
Size tires on 8" wheel
What are you 2wd guys running on 15x8 wheels? I'm running 275/60/15 & want to go to a smaller tire. Any suggestions/pics are appreciated!
Doc
1970 Sub C-10 - 350/TH-350/3.73 12-bolt
Came home from the hospital in it & mine ever since.
1966 Catalina Ventura 2-door fastback 389/TH400
doc70sub is offline   Reply With Quote
Old 09-29-2002, 08:00 PM   #2
72 Super
72 Super's Avatar
I am running 255-70-15's on my trucks.I see quite of few people running 235's also.I like the 255's because they are a taller tire.
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
Old 09-29-2002, 08:11 PM   #3
I've run both 255/70's and 235s on our wheels. The 235/70's don't have high a load range as the other tires. The 255/70's are close to the same height as the 275/60s and load range are close to the same. Exceot for snow, I don't like the skinny look of the 235s they use as the standard tire on most full size trucks. looks like a bicycle tire on a tank.
255/70's are a good comprimise far as I am concerned. Since niether of mine are heavy wortk trucks, I like the 275/60 x 15s and run them on both the 70 and 96.
Old 09-29-2002, 08:52 PM   #4
ITZA72
Paz
Depending on what your after, I've had 275/60s on 8s all the way around and know how large they are. I ended up going to a 10" rim on my SWB rears and kept the same size tire - the fronts now have 255/60s on 8s and honestly, I wished I could have a slightly taller tire. I actually mounted up 245's and removed em before anyone saw (dwarfed big time) so I'd be inclinded to go 255/70s on the sub. I've sent a few pix. If you want others let me know.
Paz@gci.net
1987 GMC SC 4x4
2004 GMC HD 4x4 Dmax'd n Edged
Rollin!
ITZA72 is offline   Reply With Quote
Old 09-29-2002, 11:34 PM   #5
doc70sub
doc70sub's Avatar
Thanks for the replies!!
Itza,
Some more pics would be appreciated. Nice truck!
Doc
Old 09-29-2002, 11:51 PM   #6
Blue_71
Bloo
Blue_71's Avatar
itza, that thing is sweet!!! makes me almost ashamed to post this now, but heres mine with 235/75/15s
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 09-30-2002, 01:01 AM   #7
ITZA72
Paz
Here's a profile shot. If you send me an email address I'll send several shots.
Paz
1987 GMC SC 4x4
Rollin!
Old 09-30-2002, 01:52 AM   #8
nate68
i have 255/60/15's on the front (8 in rim), 275 60 15 rear (10" rim)
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 09-30-2002, 09:55 PM   #9
greasemonkey
greasemonkey's Avatar
nate68- do you have a drop on your truck-if so, how much. That is about the stnce I am looking for. So you can mount a 255/60/15 on 8" rim and 275/60/15 on a 10" rim? Does the 10" rim fill out the wheel well better? I have the stock rims with 235/75/15 right now, and I am looking for something a little wider out back.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 10-01-2002, 12:53 PM   #10
nate68
2.5/4 drop (its 1/2" lower in the rear now than in the pic) the 275 60 15's will fit on an 8" rim. if you want it slightly lower in the front go with 245's instead of 255's. i went with the 255s cuz theyre wider. BF goodrich has tire specs on their website or if you go to a tire store they'll have them too.
Old 10-02-2002, 12:09 AM   #11
ITZA72
Paz
Greasemonkey
275/60s fit on 10s fine. Here's a pic. They fit great in the wheel well. I'll send more if you need. Email me at paz@gci.net if you desire.
itza
1987 GMC SC 4x4
Rollin!
Old 10-02-2002, 01:12 AM   #12
Reumster
L.E.D. Freak
Reumster's Avatar
I've ran every thing from 275/50/15 to 295/50/15 295s are actually too wide but they fit. They'll just wear a little more in the middle. But 275/60/15s are about the best size for the rear.
I'd say that 255/60/15s are about the best size to run on all 4 corners.
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 10-02-2002, 12:14 PM   #13
imaindianoutlaw
GMC SHORT FLEET F/S
imaindianoutlaw's Avatar
I think nate has it right!
CHARLES WADE HEIN
HVACR FOREMAN.
LEWISBURG U.S.P.
imaindianoutlaw is offline   Reply With Quote
Old 10-02-2002, 06:11 PM   #14
greasemonkey
Thanks. Now I know what to start looking for. BTW, anybody know the backspacing for these trucks? I don't have the energy to go pull a rim off right now.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
Old 10-02-2002, 08:30 PM   #15
HvyChevy454
Slowly getting CRSS...
HvyChevy454's Avatar
235/70/15
-Nic
Lutz, Fl
My Team Website
The Heavy Chevy Website
  • 72 Cheyenne 10 LWB GM 12-bolt 3.08 w/ Auburn Posi
    91 454 Edel Performer RPM Intake 750 cfm carb Comp Cam 268/.495 Hedman Headers Dual 3'' Exhaust
  • 71 Cheyenne 20 4x4 Fact. A/C PS PB Tilt Currently in the works...
Speak Softly and Carry A Big Block...
There is No replacement for Displacement...
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
HvyChevy454 is offline   Reply With Quote
