![]() Join Date: Aug 2007
Anyone using the tubular motor mounts?
instagram "footbraker67"
Re: Anyone using the tubular motor mounts?
yeah ive got em on my 67 and love em, i had to cut quite a bit of frame out but the end result is great
I have them also. Didn't have to do any mods. Just bolted them on and lowered the engine. Sure beats the other type......
1997 GMC Sierra Ext 1965 Mustang |
Official Site Guitar Shredder
these look awsome.........how does the chrome wear? i am guessing they see soem heat right? do the blue or discolor?
Good enough for me. I'll be gettin some.....
I wonder if the painted ones are only available in blue?
“If you don’t have time to do it right now, how will you ever find time to fix it.” - author unknown '70 SWB Step-Side (More rust than metal) ![]() |
Was thinking that too, the first time I found them, they were available in black only.......
the ones i got were black, the other choice was chrome but they peaked the budget a little too much and I figured nobody would see them anyway so i went with powdercoated black and they look really good in my opinion.
Throbbing Member
![]() Join Date: Jul 2006
Hey guys, here are the same mounts as pictured above but at Brothers for $129. Here is a linkie:
http://www.brotherstrucks.com/prodin...number=ESM6372 They seem to be really good quality |
Probably an ignorant question...what is the benefit of these mounts? Fix clearance issues?
Throbbing Member
I purchased them all for looks. I have heard that it helps with some clearance issues, just don't know for sure
I have them in my 68.
SBC w/some 3/4 length Camaro headers. Fit seems good & there were no clearance issues. Truck hasn't been on the road yet for any other experiences.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-09-2007 at 03:34 AM. |
#13 |
This is where I got mine. Comes as a kit with all hardware and motor mounts.
http://www.performanceonline.com/sto...96&cat=0&page=
#14 |
wow...man...ahh that's tubular! LOL!
Alex 1971 Lil' Red 350 SBC 700R4 |
#15 |
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#16 |
The item description at www.performanceonline.com states, "upgrade your old V-8 mount to the much more common car motor mount pad". What is the difference between the truck and car motor mount pad? Is it something worth upgrading?
#17 |
I had two reasons for using them on my 67. one is because I had heard from a few people that the stock truck style ones are known for wearing out quickly and judging by the shape mine were in I totally believe them. secondly I swapped over to vortec style exhaust manifolds(got tired of tightening header bolts) and I had a clearance issue with the stock mount.here is a pic they are hard to see but you kind of get the idea.
#18 |
That oughta fix my pump clearence issue, I had to cut some of the tower away when I installed the bigger GMPP pump on my motor to clear the inlet fitting
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap |
#19 | |
Car |
#20 |
I used these for my big block conversion, zero issues..other than payin for em.
#21 |
Farm Truck
![]() Join Date: Aug 2006
Will they work with a 454 cid?
1969 CST/10 1984 K5 Blazer 4x4 2016 Dodge Ram 2500 4x4 Mike Jersey Village, Tx |
#22 |
There stronger and a more common design from the old truck ones, all the newer trucks and cars used em
#23 |
#24 |
Junior Member
I bought these to use in my 68 but I am going to use solid motor mounts for the BBC. First motor mounts I ordered were too tall but second set looks like they will work ( Moroso stuff) just havent had any time to work on it. Guy said they are plenty strong, guess well see.
Kinda tuff looking at the 567 BBC sitting in the floor and knowing it will have to wait.
68 GMC 565 BBC Abruzzi super pro glide 9.85@135.00 ![]() |
#25 | |
