Old 09-08-2007, 07:08 PM   #1
Jcentsr6
Junior Member
Jcentsr6's Avatar
Tublar A-Arms???
what benefit's are there to tubular A-arms?? Please let me know, thanks.
(other than looks?? )
Sorry bout the spellin LOL
going to sell this one...looking for a SWB project next.
Jcentsr6 is offline   Reply With Quote
Old 09-08-2007, 07:14 PM   #2
SCOTI
SCOTI's Avatar
Re: Tublar A-Arms???
ART advertise better geometry on their arms..... not sure about other brands.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-08-2007, 07:18 PM   #3
Jcentsr6
Junior Member
Jcentsr6's Avatar
better geometry.....Means?? In the real world?
Old 09-08-2007, 08:27 PM   #4
abadsvt
abadsvt's Avatar
With the strong arms (ART) they change the mounting angle of the ball joint to help it from binding up for lowered trucks. It is only a few degrees but it is supposed to make a difference. I would imagine that most of the companies that make aftermarket control arms would do the same thing. Besides the tubular A-Arms just look alot better!!!!
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 09-09-2007, 08:30 PM   #5
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
on my truck, it's the difference between the control arms scraping on te ground and them not. It's also the difference between the uppers hitting the frame and not. plus they look cooler.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 09-10-2007, 07:56 PM   #6
lost wages
lost wages's Avatar
i have the air ride strong arms on my truck, for a lowered truck they added in positive camber (less shims to align the front) and more caster (less bump steer), the ball joint angle is lessened also. the only downside to the strong arms is you have to use air ride techs sway bar.
lost wages is offline   Reply With Quote
