Junior Member
Pics inside/ Early Classic Stainless Hoses
Just installed my new Early Classic stainless steel brake hoses and was wondering if anyone had to grind their calipers like this to make their brake hoses run properly?
![]() Join Date: Aug 2005
Re: Pics inside/ Early Classic Stainless Hoses
I had to grind a little on mine when I replaced the calipers with a reman pair. I'm not sure where the compatibility issue came from because the discs were installed by a previous owner. I even tried swapping the lines side-to-side, but as you probably found out too that does not work... Grinding the calipers did the trick.
