Old 09-09-2007, 01:16 AM   #1
outlaw005
72 Super Cheyenne light problem
Missing all rear lights including back up lights. All fuses check good. Any ideas on what the problem is? Thanks
outlaw005 is offline   Reply With Quote
Old 09-09-2007, 01:19 AM   #2
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Re: 72 Super Cheyenne light problem
tested voltage to tailights? could be a cracked wire.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 09-09-2007, 02:57 AM   #3
RyanG
RyanG's Avatar
Had that issue and found that the wires coming through the firewall were seperated......however I still do not have reverse lights.I haven't really put that on my immediate fix list. Until I get a ticket for it/
RyanG is offline   Reply With Quote
Old 09-09-2007, 03:03 AM   #4
blukangoo
Neighborhood Pickle Slinger
blukangoo's Avatar
In my 68 I have another connector in the back. My reverse lights didnīt want to work either. I cleaned that connector and they worked fine.
My C10 Diary
Our cars:
1966 Chevrolet Chevelle 396 - TH350
1968 Chevrolet C10/CST 327 TH400/375
1969 Corvette Stingray 350 - Muncie Manual Trans
1969 Chevrolet ElCamino 350 - TH400
1970 Cutlass Supreme Convertible - 350 Rocket - TH350
1973 Camaro LT - New Engine Done - TH350
1973 Corvette Convertible 454 - TH400
blukangoo is offline   Reply With Quote
Old 09-09-2007, 10:33 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
there is a plug ont eh firewall, and one under the bumper, actually at the rearmost crossmember, either of those could be unpludgged, but it isn't likely.
I would start with grounds. Has the been just been installed, and/or does it have a wooden floor?
Old 09-09-2007, 10:50 AM   #6
smoked68
smoked68's Avatar
I had the same type problem a few weeks ago. It was a ground issue. Took the light assemblies out on both rears sanded the back of the housings and then the truck frame where they screw to the frame. All started working as they should then. Good luck.
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 09-09-2007, 11:43 AM   #7
68gmsee
Active Member
68gmsee's Avatar
Also, don't forget the reverse lights switch on the steering column...
68gmsee is offline   Reply With Quote
Old 09-09-2007, 04:22 PM   #8
raws67
raws67's Avatar
About one month ago I bought an engine down by LA and was driving back from LA over the grapevine and I had no tail lights in the dark, not a place you want to be without lights. After scratching my head and calling a buddy with a wiring diagram I climbed underneath and followed the harness down the frame and there it was the round plug near the rear bumper I believe it was along the drivers side frame close to where they hang rear tires on newer trucks. The harness came loose just enough to still be hooked up but not make contact. If all your rear lights are out then that would be my best guess. Good luck
raws67 is offline   Reply With Quote
