GM ONLY BABY!!!
Air ride installed, not much lower on 18's.
Ok, how low are you guys sittin with your air ride? I have 3" drop spindles on the front. I cut 1 round of coil out of the front springs, but now i'm not even sitting 1" lower with the S/s re-7 bags. I have a 37" x 6" or 7" tank. How many gal. is that? I'll post some pics sooner or later. Oh ya, just cruised up to Michigan today to p/u a 72 Chevy lwb, 79k truck, tw, pb, a/c p/s, all there, ochre/white, $1700, drove it on the trailer, for a buddy of mine.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
![]() Join Date: Aug 2005
Re: Air ride installed, not much lower on 18's.
Did you cut down the cups?
GM ONLY BABY!!!
No, not yet. I assembled it in a stock configuration to see what it looked like. How much can I remove from the bottom cup?
From what I've read they can go down to 3/4" total height. I kept mine at 1.5" because I wanted the RE7 internal bumpstops to be the first thing to bottom out. After I mod the inner fenders and re-route the exhaust I may go a bit lower with them.
A guy with a truck
With the 63-72 arms, you can take about an inch off. With the 73-87 arms, you can take them to about an inch. This assumes ***************** cups...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 09-09-2007 at 08:26 PM. |
I've seen guys report that they're getting cups of differing heights form SD. That's why I quote the total height you can cut down to.
A guy with a truck
Do you have the early arms? Do you think you could trim them more without the bag rubbing? I tried to fit up some cups I have that are 3/4" and there is no way they'll work with the early arms.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
I have '69 arms but I've never used 3/4" cups, only 1-1/2". I have seen a lot of people on here saying you can go to 3/4" including KPComponents. However, when I put mine in I wondered how well 3/4" would work. Seems like the bag would end up sandwiched between the arm and the upper plate when aired out, but maybe that is considered acceptable
A guy with a truck
Even aired up they sit on the arm. I don't see it happening- the 73-up arms are a different story altogether. Totally different design...
Outlandish Trends - FL
That leads me to believe that I have the 73+ arms on my truck already Gringo. I know I've been slacking but I'll get pics up soon. I've got my cups trimmed down to 3/4" and I have -0- rub issues.
-Bret 67 short-fleet sold! |
GM ONLY BABY!!!
Yes, I have suicidedoors cups. My truck is a 72, so I will disassemble it soon and cut the cup down to 3/4" or so. I'll try to post some pics of before and after the mod. Thanks guys!!
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up Last edited by chevydog66; 09-10-2007 at 10:11 PM. |
I was wondering about this myself. I have an '82 front crossmember and re7 bags. My cups are 1" total height, and my bag rubs slightly on the rear edge of the coil pocket at full dump.
#13 |
hey, Frizzle fry wheres the Coys! Have you gotten your tires yet? Was just curious what brand/sizes you were gettin
#14 |
GM ONLY BABY!!!
3/4"?? Does that include the mounting plate or just the depth of the cup. Because the plate is about 1/4" thick.
#15 |
Commander Taco Bello
includes the plate. At least that's how i cut mine
#16 |
GM ONLY BABY!!!
So the depth of the cup would only be about 1/2"? Right?
#17 |
A guy with a truck
Does anyone have pics of the 3/4" tall cups in a 63-72 arm? I do not see how this could possibly work, but i have been wrong before. Once.
#18 |
I'm leaning toward your side on this now Gringo. Here are a few shots of my 1.5" cups (total height) in 63-72 arms. You can see that there is some contact between the bag and the arm when fully collapsed. However, it's no worse than on the top plate. I don't think I want to cut them down any further. So, even though I started by saying I've read 3/4" would work, I don't see how it's possible with these arms. I stand (sit) corrected
#19 |
#20 |
I think FrizzleFry is correct, it depends on the depth of the spring cup in the a-arm. On my '69, I didn't think I could have gone lower than the depth of the spring cup, or about 1" total height.
I never got around to cutting my cups because I liked the stance with the back uncut. I am going dropmember next time, I just need to find a truck.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
#21 |
GM ONLY BABY!!!
From the looks of mine, I think I can cut about 1/2 or so from my cup. Here are a few pics of the way it sits now. Oh, and 1 bonus picture of Ashley Force and I. The beer and sun and Nitro had got to me by the end of the day.
#22 | |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 09-12-2007 at 07:46 AM. |
#23 |
GM ONLY BABY!!!
Gringo, yep that is aired out, with 3" drop spindles. Did you guys see her on Leno the other night. Damn, she's HOTTTTTTT!!!!!
#24 |
The LuvShack Garage
Still trying to understand this all also, it looks like w/ stock arms (71) that
I can't cut my cups that much like Frizzle said, but I also remember him in another post saying he had to trim his Swaybar cause it was into the bag, mine is not, maybe I have a slightly more slender set of bags? I need a lil more of the front, this is the aired out pic with the 15's and then the 17's you can't see the back but it needs to come down more, but if I do that I will be inverted ![]() I can decide how much mine need to be trimmed, or I might just get arms. Edit: also added a side pic, all be it with the old rim set-up which are 15" and I am NOT interested in laying frame, way to old for that stuff and it gets driven pretty far when available. So I want to be able to run her all aired out incase I ever have a bag issue and I am a long way from home. Bottom pic is 25" front ctr of wheelwell, and 27.5" rear ctr of wheelwell, now with the 17's on it she is still 25" out front, and rear is now at 25.5"
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 09-12-2007 at 03:23 PM. |
#25 | |
I think any less than that you run the risk of the bag touching the arm. At least that's my understanding. Compare this picture to the one of FF's install. See how much of the cup is visible above the lower arm? ![]() You could cut about a 1/2" or so off the cups in this picture.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 Last edited by jimmydean; 09-12-2007 at 03:48 PM. |
