C-Notch help...
I have the pipe to C-Notch my frame and I have the plate to box it in.
My leafs and rearend are already installed. I have it marked where the C-Notch needs to go. Should I unhook my leaf from the shackles and support the frame on both sides then cut out the notch, weld in the pipe, and then box the area? Or is it ok to leave the leafs connected and just support the frame on both sides then cut out for the notch, weld in the pipe, and then box the area? Also, is about halfway up the frame as deep as you want to notch it?
Lotus Current Rides/Projects 1955.5 Chevy shortbed truck 1952 Chevy Coupe Deluxe car |
Yellow truck club
Re: C-Notch help...
You could leave it sitting as is, box it first then cut out the notch. I also drilled a hole in the pipe at the top of the notch and welded a nut on top for a bump stop to thread into. I used one off of a set of traction bar. I would not go much more than 1/2 way
Brian ....
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() 59 Chev Apache ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
Hollister Road Co.
Re: C-Notch help...
the only thing I would add is have jack stands under the frame in front and back of the notch area.
| Bookmarks |
