![]() Join Date: Sep 2006
Big Block guys?
Did you move your engine mounts up to get it to fit or did you cut the firewall to get the valve covers to clear..... Don't tell me you beat the firewall with a hammer. That is unexceptable..
![]() Also.. Did you use the stock 65 mounts or did you upgrade to the newer mounts?
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 09-09-2007 at 01:36 PM. |
Re: Big Block guys?
try this link http://67-72chevytrucks.com/vboard/s...d.php?t=229284
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN 62 HARDTOP NOVA 65 CHEVROLET BB LWB FLEETSIDE 90 CHEVROLET EXTRA CAB CHEVY ONLY - NZ Chapter http://67-72chevytrucks.com/vboard/s...d.php?t=137984 |
Re: Big Block guys?
Re: Big Block guys?
I used tubular engine stands from performance online, and mounted them in the forward holes. No clearance issues with a big block and pretty tall valvecovers. I am running hydroboost brakes though, and that makes a huge difference on clearance w/ the vacuum booster. Hydroboost = no giant pancake thingy to get in the way.
HTH |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Big Block guys?
When I did my Burb, I used the '73 and newer mounts and made custom brackets to move it forward just enough to clear the valve covers I wanted to use. I know that may not help if you don't have welding capabilities, but IMO the '73 and newer motor mounts are better. The frame brackets for those mounts may work....IIRC the '81 and newer may work a little better.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 09-15-2007 at 01:35 AM. |
