Old 09-09-2007, 08:10 PM   #1
ken71gmc
ken71gmc's Avatar
Stainless or Aluminum? Movin' tank out back
Howdy all! Have smoothed the old tank filler in the cab hole and am doing the gas tank to the rear. Bought a poly tank early on in the resto and don't care for it. Mounting is weak, my biggest beef. Anyones ideas on either aluminum or stainless and a company would be appreciated. Aluminum tends to be less expensive but if stainless is tops I'll fork out the extra dough. Using the bed fill and probably hinged lid to cover filler. Anybody with pics or suggestions on websites please bring it on. Thanks and have a great one.
ken71gmc is offline   Reply With Quote
Old 09-09-2007, 09:14 PM   #2
Kid
Kid's Avatar
Re: Stainless or Aluminum? Movin' tank out back
Stainless or aluminum both make good fuel tanks. The Stainless would be less weight, but like you said, would cost more. To give you some ideas, take a look at the link below to see an aluminum tank I built & installed in my 68.
http://67-72chevytrucks.com/vboard/s...ad.php?t=50348
Kid is offline   Reply With Quote
Old 09-09-2007, 10:23 PM   #3
Ram-Man
Ram-Man's Avatar
One thought on mounting the plastic one use straps like the factory does. The plastic one I bought was designed to be hung. If you get smacked in the rear (no pun intended) you want that tank to rip the straps off and not be bolted solid and end up tearing a hole in it. You wont see a production vehicle with a under vehicle tank bolted in solid. Only hung by straps.
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 09-09-2007, 10:34 PM   #4
see ten
WTB this ad
see ten's Avatar
Tucker's has a nice looking aluminum one. Early Classic also has a stainless steel one that looks tip top.
see ten is offline   Reply With Quote
