Old 09-09-2007, 10:24 PM   #1
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Who's running the most compression...
On the street ???
If you have a sound / vid clip that'd be great
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 09-09-2007, 10:44 PM   #2
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: Who's running the most compression...
I'm running 22 : 1 in my '67 C-30...
But it's a Diesel!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 09-09-2007, 10:52 PM   #3
BCOWANWHEELS
10.1 with iron heads and dist. 36deg. full advance you,ll have to run at least 93 oct. for sure as thats what my 383 is. it will valve rattle like crazy if you dont. 11.1 with alumin heads same thing. 9.1 is all around best for street i think.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 09-09-2007, 10:53 PM   #4
67_C-30
67_C-30's Avatar
I've run as high as 10- 10.3 : 1 on a cast-iron headed SBC with a carburetor, but that's pushing it. I'm running a 12.2 : 1 CR 383 in my '82 Z28, but obviously, I'm running race fuel.
My trucks
Old 09-09-2007, 10:55 PM   #5
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
8.5 to 1 on the maro, oh wait highest? i lose haha
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 09-09-2007, 10:56 PM   #6
DieselEater
DieselEater's Avatar
My current pulling engine is going into my 68' SWB project.....11:1 on 91 octane w/out problems........but I'm at 7000 feet elevation 840 rectangles, 800 Q-Jet, RPM air gap.
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
http://profile.myspace.com/index.cfm...ndid=127691959
DieselEater is offline   Reply With Quote
Old 09-09-2007, 11:07 PM   #7
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Cool, anybody run'n propane (LP) ???
Sinister
Killer
Old 09-09-2007, 11:21 PM   #8
yenko427
yenko427's Avatar
Hey everyone I'm new to performace stuff. How do you measure comp ratio I have a comp. gauge that I got from a friend.
yenko427 is offline   Reply With Quote
Old 09-09-2007, 11:30 PM   #9
DieselEater
Find your chamber size of your heads with your casting number......Go to Mor-Tec.......Then you must know what size/type pistion you're running.
example.....840 BBC iron heads have a 107cc combustion chamber + my L2349F TRW pistons spec sheet says that with 106.9 chambers I'll be around 11:1. If you don't know what piston you have, but the engine is stock, you can get an Idea of what piston was used from some GURU types around the net.
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
Old 09-10-2007, 12:05 AM   #10
72 CustomCamper
huh ???
72 CustomCamper's Avatar
But it's a Diesel!
That's what mine was when I had the 6.2 in my 72...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 09-10-2007, 04:59 AM   #11
bb1979
bb1979's Avatar
I'm running propane I think my motor has something like 10:1 compression, and it runs great I've been told that 13:1 is acceptable with propane without any issues
1979 C20 pickup 454 big block turbo 400, 4.56 gears
bb1979 is offline   Reply With Quote
Old 09-10-2007, 06:04 AM   #12
18:1 in my 6.5TD.They actually can be made to run better by lowering from 22:1,sounds silly,right?
I`m picking up my fresh 327 today.It will be about 9.5 to 9.7:1 w/iron heads.I may get away with regular.It will be awhile before it sees service to find out.
Old 09-10-2007, 06:13 AM   #13
bad6772
Official Site Guitar Shredder
bad6772's Avatar
9.5 but im going to a vortec S trim over the winter, my lower end is basically stock ZZ3 but i have had a ton of head work,( port polish port matched to my intake three angle vavle job dual springs, 2,02 1.60 valves and ported and ploshed my intake lil bigger cam (roller) , and of course my erson (extremly loud ) gear drive ,< i think it steals ponies though.... lol but it sounds awsome.........oh i lose
bad6772 is offline   Reply With Quote
Old 09-10-2007, 08:02 AM   #14
67_C-30
67_C-30's Avatar
Not silly at all. You can turn the boost on up with the 18:1's w/o blowing head gaskets and melting holes in pistons!
My trucks
Old 09-10-2007, 09:54 AM   #15
djracer
djracer's Avatar
I have 14 to 1 pistons in my junk but I run race gas! I will run as low as 112octane without the spray but only 116 to 118 when its on the bottle!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 09-10-2007, 10:04 AM   #16
crazy longhorn
Fabricate till you "puke"
I run 9.8 on my alum headed 383, with 34 degrees of mechanical advance ,all in @ 2700 & 12 additional degrees in the advance can. Its fine on 91 octain fuel, but will ping a trace on 89 pulling a steep hill. L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-10-2007, 02:24 PM   #17
jkade
jkade's Avatar
I will be running about 11.5:1 on my iron ls1.
jkade is offline   Reply With Quote
Old 09-10-2007, 03:53 PM   #18
snj8198
snj8198's Avatar
8.9 cr in my MKIV block. a bit low for aluminum heads but im building a decent amount of cylinder pressure to make the best of my lower duration cam and flattop pistons.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 09-10-2007, 04:10 PM   #19
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
What system are you running ??? Holley Pro-Jection ???
Are you LP only or can you still run off gas when you need too ???
Sinister
Killer
Old 09-10-2007, 04:22 PM   #20
djracer
djracer's Avatar
my buddy had a 13 to 1 440 in a 70 duster but we had to mix av gas and super! It was one fast car for the street!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 09-10-2007, 06:10 PM   #21
mark's68
I've got a 388 with 10.6-10.7, sportsman heads but it lives on 100 octane low lead avgas. It realy likes it.
mark's68 is offline   Reply With Quote
Old 09-10-2007, 07:01 PM   #22
kelsfine69
18 Till I Die
kelsfine69's Avatar
454 BBC LS7 12.25:1 crate engine with port and polished heads/matching intake and a 850 Holley. Premium and avegas 60/40 mix or premium and octane boost when the drum runs dry.
Kind of a crappy clip
http://www.youtube.com/watch?v=5ru1cCe62JQ
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 09-10-2007, 07:53 PM   #23
Scott68-93-97
Scott68-93-97's Avatar
You can run propane at 13 to or 14 to 1 no problem in fact it will help maximize power to fuel consumption raising compression, propane is 105 octane and loves high comp.
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
Old 09-10-2007, 08:25 PM   #24
bryanw1968
bryanw1968's Avatar
10:1, no problems on pump gas at 12 degrees initial. I can bump up the timing some with some 104 race fuel in it.
bryanw1968 is offline   Reply With Quote
Old 09-10-2007, 09:19 PM   #25
raceman29
raceman29's Avatar
i had a det of 601 heads off a 305 and put them on my 355 race engine. ran 11:1 ran super unleaded and av fuel 50/50 around 32 degrees advance. dirt cirlce 6500 rpm. hottest would run was 230 degrees no problems. combustion chambers were 55cc and flat top 2 brow pistons.
raceman29 is offline   Reply With Quote
