Old 09-10-2007, 10:20 AM   #1
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Brake question?
A couple of weeks ago I had 4 new drums, 4 new wheel cylinders, and new shoes all the way around installed. I have driven it a few hundred miles. Well this morning I get in it and the pedal goes to the floor. At first you could pump the brakes and the pedal would firm up but not any longer. I am thinking master cylinder. What do you think?
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 09-10-2007, 10:30 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Brake question?
Do you have any brake fluid leaking down the inside or outside of the firewall below the master cylinder? Is the Master cyl low on fluid? Is there brake fluid on any of the backing plates or running down the inside of any of the tires? This will give you some things to look for and will help the guys on here diagnose the problem.....
LockDoc
Leon
Old 09-10-2007, 10:33 AM   #3
1969K10
1969K10's Avatar
Re: Brake question?
I agree with LockDoc, also look at your flex hoses!
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 09-10-2007, 10:34 AM   #4
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: Brake question?
I don't see any sign of the wheel cylinders or the master cylinder leaking. The master cylinder is full of fluid.
Old 09-10-2007, 11:07 AM   #5
LockDoc
LockDoc's Avatar
Re: Brake question?
I guess I would have to say MC then. Even if you have a lot of air in the lines they should pump up to something..... Try pumping the pedal by hand 5 - 10 times and pull the pedal all the way back instead of letting it come back on it's own. Do they pump up at all then?
LockDoc
Leon
Old 09-10-2007, 12:14 PM   #6
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: Brake question?
LockDoc
NO. Straight to the floor.
Old 09-10-2007, 02:19 PM   #7
LockDoc
LockDoc's Avatar
Re: Brake question?
I would replace the MC then.
LockDoc
Leon
Old 09-10-2007, 03:44 PM   #8
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: Brake question?
My Dad turned me on to a guy who will replace it including the part for
$70-85. I don't rally know how to been blled the new one so I am going to drop it off tonight. I figured for that price I would just have it done and have him replace fluid and bled.
