Old 09-30-2002, 12:18 AM   #1
Yellow Cheyenne
Question Help identify a 3/4 ton rearend
I am parting a '72 Chevy Longhorn 3/4 ton pickup that has what I believe is a non original rear end. The rear axle has 1/2" studs that are smaller than what the front discs have (9/16" I think). The rear housing also has some paint left on it as opposed to the rest of the under carriage.
Both the front and rear of the center section can be removed. The rear cover has 10 bolts in it and is basically smooth. The front is cast iron and I believe it also has 10 bolts holding it in. It is a full floater set up. The pinion input can be unbolted from the rest of the front cast iron piece. The only numbers I could find on it are on the front left side of the cast iron piece and the numbers are 3834635. Can anyone help identify this piece? Thanks in advance.
'72 Cheyenne. AC, PS, PB, Rear slider window, tilt. Light yellow (grapefruit yellow according to new sales literature from '72)
'56 Chevy short step V-8 (My dad bought it new!!)
'70 Olds 442 convertible
'70 Olds Rallye 350
Yellow Cheyenne is offline   Reply With Quote
Old 09-30-2002, 12:36 AM   #2
chevynut
chevynut's Avatar
If you could post a pic of the rear pumpkin it should be easier to identify.
Mike
1989 C1500 SWB Reg Cab
2003 Chevy Tahoe Z-71
70 Camaro RS/SS - 454
chevynut is offline   Reply With Quote
Old 09-30-2002, 12:52 AM   #3
mikep
Used to have a truck
mikep's Avatar
Sounds like an eaton .
No truck :-(
mikep is offline   Reply With Quote
Old 09-30-2002, 02:24 AM   #4
Blue_71
Bloo
Blue_71's Avatar
sounds like eaton to me too, my 71 3/4 ton 4x4 one has 9/16 threads though
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 09-30-2002, 10:51 AM   #5
ckhd
ckhd's Avatar
Yeah, it's the "Eaton" or H-072/H-052 (same thing, different names). My '68 H-072 has 1/2" studs.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 09-30-2002, 11:15 AM   #6
mikep
mikep's Avatar
I know where one is around the Seattle area in a boneyard with the "maximum traction" option if anyone wants it. ala detroit locker . Its under a 67 and has 4.10 gears
No truck :-(
Old 09-30-2002, 11:41 AM   #7
crew70
crew70's Avatar
remember now the only diference between a ho52 and ho72 is the ho72 has 13in brake drums and only came on daullys.
70 chevy 3/4 ton 4x4 402ci crewcab
3/4ton
94 gmc 1 ton dually crewcab 454ci
99 suburban 5.7
2001 500cc ski-doo mxz
95 500cc ski doo fan
650 bombardiar 4 wheeler
crew70 is offline   Reply With Quote
Old 09-30-2002, 01:19 PM   #8
ckhd
ckhd's Avatar
I thought it was the H-110 that came on duallies...
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Old 09-30-2002, 01:45 PM   #9
jku72
I have an HO 72 under single rear wheels. But I do think the only difference is in the brake size.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 09-30-2002, 02:38 PM   #10
COBALT
COBALT's Avatar
Does it look like this?:
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 09-30-2002, 04:47 PM   #11
crew70
crew70's Avatar
yep,ho52.
3/4ton
99 suburban 5.7
Old 09-30-2002, 09:51 PM   #12
Rod
There was an 11000 lbs gvw rear end that came on 1 ton duallies also... but it has ten studs on the drums. Still the truck was rated as 14000 lbs total.
My dually has the 7500 lbs rear with the aux spring kit that made it a factory 11000lbs rear also but is 8 bolt stud pattern. 9/16 studs in 70 up I believe maybe just 71-72.
The 11000 pound factory rear had vacyuum assist brake pods that mounted under the cab.... once you see one you will always remember the difference. Sorry no pic.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 09-30-2002, 09:59 PM   #13
mikep
mikep's Avatar
OK...Why does my 7500 GVW 68 3/4 ton C20 with heavy duty coils, 4speed , and originally a factory big block have a dana 60 while all the other similarly equipped trucks I have seen have Eatons? Was there any formula to determine which trucks would have what rear ends?
No truck :-(
Old 09-30-2002, 11:49 PM   #14
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If not mistaken, Danas were just another option that should have been opted for a more trucks than they were.
Old 10-01-2002, 12:15 AM   #15
mikep
mikep's Avatar
I just checked my option sheet. I got it along with the protectoplate, '68 service manual and warranty book. Not bad for $500. Other than HD rear springs and 396 engine there is nothing concerning the driveline. I did see a 67 in the boneyard the other day. I go once or twice a week . I've been a junkyard junky since I was 12. It had a eaton with a detroit locker and was optioned as such on the build sheet behind the rear seat as "extreme traction" or something like that. I check those . I am a dork . I'm thinking the Eaton was the option and the dana was the standard rear end under 3/4 tons. It might have been what they later called the heavy 3/4 ton option.
No truck :-(
Old 10-01-2002, 12:18 AM   #16
Longhorn Man
Dana was not standard.
Many things never made it to the option sheet. For example, the leaf/coil spring debate. I have never seen (in person) an option sheet that states one or the other, yet my GMC has coils in back, and I have seen a few leaf spring 1/2 ton chevys...
Lots of mysteries.
Old 10-01-2002, 12:51 AM   #17
mikep
mikep's Avatar
Thats right. The build sheet had it listed as "Maximum Traction"
Sounds rather ominous doesnt it?
No truck :-(
Old 10-01-2002, 09:18 AM   #18
Yellow Cheyenne
Cobalt. Mine does look like that, except mine is a leaf spring set up. I will check for posi and ratio and let everyone know. Thanks to everyone for helping me out.
'70 Olds Rallye 350
Old 10-01-2002, 01:42 PM   #19
COBALT
COBALT's Avatar
Well, I may catch heat for what I'm about to say, but it won't be the first time on this topic. longhornmail hit on it in his previous post. There's some large patches of grey area when it comes to the rear suspension/differential debate. It is NOT as standardized as people might think. The numbers on the differential you see in the picture above match to an HO72. Now before everyone jumps on me I checked this out, and technically you guys are correct about the configuration issues of leaf vs. coil sprung suspensions and 5200, 7200, and 11000 axles with or without the HD spring and/or overload spring options. All that aside the differential codes are what they are. Mine does not match the numbers for an HO52.
Another thing. I think I mentioned in another post that these axles aren't technically "Eaton" axles. This is a source of confusion for a lot of people. Eaton made the carriers, and the optional posi units and such, but they didn't produce the whole axle.
Seattle, WA.
Old 10-01-2002, 07:38 PM   #20
crew70
crew70's Avatar
ok i am going off of what I have learned from you guys on the board.
anway can you tell from my code what it is?
3934635
3/4ton
99 suburban 5.7
Old 10-01-2002, 07:42 PM   #21
COBALT
COBALT's Avatar
That's the casting number of the housing. Look in these areas for all of the codes. Like an engine you have to use them all to figure out what you have, and then there's a website that can tell you (don't remember the URL-sorry):
Seattle, WA.
Old 10-01-2002, 08:05 PM   #22
crew70
crew70's Avatar
ok heres what I found
tpw1222g
3843067
3934635
couldn t find any numbers on the yoke like it says in your pic.
3/4ton
99 suburban 5.7
Old 10-02-2002, 01:43 AM   #23
Yellow Cheyenne
I opened mine up tonight. It is 4.10 non posi/non locker. It is in good shape if any one wants it. Otherwise it will go to junkyard this weekend.
'70 Olds Rallye 350
Old 10-03-2002, 11:59 AM   #24
COBALT
COBALT's Avatar
crew70: check inside the yoke. There should be a huge-a$$ nut inside that should have some codes stamped into it...
We went to all this trouble for a junked differential? Oh well it's good info.
Seattle, WA.
Old 10-03-2002, 12:42 PM   #25
Yellow Cheyenne
It's only junk of nobody wants it.
'70 Olds Rallye 350
