Old 09-10-2007, 09:48 PM   #1
theside00
4:56 gears need to change
Went on a camping trip and drove a couple hours on the freeway and was pushing 3,000 rpms with a 454 just to go 65-70. I am thinking about raising the gearing to 4:11 or higher. Anybody think this is a good idea?
Sorry I had to edit your post. You need to be a subscriber to trade, want to buy or sell.
oldiron
forum staff
See link below to subscribe.
theside00 is offline   Reply With Quote
Old 09-10-2007, 10:19 PM   #2
69halfton
69halfton's Avatar
Re: 4:56 gears need to change
been thinking of some 4.56 gears in my truck, although i have a 12 posi. do they even make 4.56 gears for a 12 bolt? never run across them?
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 09-10-2007, 10:35 PM   #3
wibilly
wibilly's Avatar
you must have some pretty tall tiresif thats all the rpms you are turning. i used a calculator online somwhere and came up with 2600rpms at 64. somthing with 4,10s and 33"tires
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 09-10-2007, 10:51 PM   #4
theside00
I am running 39.5s right now and thinking about going down to 38 and that is going to kill the highway travel even more. Figure that 3,000 RPMs on the highway is a little to much for the 454 for long periods of time.
Old 09-10-2007, 10:53 PM   #5
wibilly
wibilly's Avatar
yea they are som big as tires
Old 09-10-2007, 10:59 PM   #6
bad6772
Official Site Guitar Shredder
bad6772's Avatar
im running 4.56 gears in my lwb 26 inch total tire wheel combo... its a pain on the freeway. 60 is about the max....3400 rpms.....and it tops out at about 90 mph ...but does it real quick....when i did a little friday night racing went to 10.5 mickey thompsons, 29'' tall. rpms was alot better
bad6772 is offline   Reply With Quote
Old 09-10-2007, 11:05 PM   #7
Twistedsteel
Twistedsteel's Avatar
Yeah I got em in mine, I run 35's and it's not a nice freeway cruiser.
theside00,
What kind of tranny are you runnin? I wouldn't go any lower(number wise) than 4.11 with those big tires. If your runnin an auto it will kill it quick. Maybe put in a overdrive trans or a overdrive from gear vendor.
Albie
Twistedsteel is offline   Reply With Quote
Old 09-10-2007, 11:08 PM   #8
Twistedsteel
Damn! I run about 3000rpm goin 55-60 with 4.56 and 35's and a th350
Old 09-10-2007, 11:08 PM   #9
theside00
There is just a th350 so running smaller might kill the tranny. If the th400 final drive ratio the same as the th350? That is a swap I would like to do to have a tranny that can handle the power from the built 454.
Old 09-10-2007, 11:16 PM   #10
Twistedsteel
Not sure on the final drive gears but a Th400 would be nice and I would look into adding a overdrive on it. Not sure how much power the overdrives handle, might want to look into that.
Old 09-11-2007, 12:12 AM   #11
wheels67
wheels67's Avatar
hmmm My original 327 with a th400 and 3:73 gears are killing me as
well on the freeway.
A 200r4 is almost a direct bolt in but are weak.
A 700r4 requires driveline shortening and crossmember movement
but can be rebuilt to handle the load......the overdrive swith can be mounted down by the dimmer switch on floorboard........the projects never end...lol
wheels67 is offline   Reply With Quote
Old 09-11-2007, 07:26 AM   #12
1LoC10
Insert Title Here
1LoC10's Avatar
I have 4:56 gears in my 12 bolt with a 3 on the tree and 255/70/15 tires... sucks on the highway, adn im shifting into 2nd before i leave the driveway
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 09-11-2007, 09:48 AM   #13
grayw0lf
4.56 here w/ 12 bolt, Th350 & 255/60/15's.
It sucks!
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 09-11-2007, 11:06 AM   #14
AlienYouth
AlienYouth's Avatar
final drive in TH350 and 400 are both 1:1
Picturesss
71 C10 383/TH400
13.65 @ 99... 2.06 60' spinnin :/
AlienYouth is offline   Reply With Quote
Old 09-11-2007, 03:05 PM   #15
gkolmatycki
Love that '69
I have the same problem you do & know your pain. I have 235/75/R15's with a 283/TH350 combo & 4.56 gears in the rear end. On the highway at 70 MPH she's at almost 4000 RPM's. But she gets there pretty quick!!!
I AM CANADIAN & PROUD OF IT!!!
1969 Chevy C10, SBC V8, TH-350 Transmission, Metallic Blue, B&M Megashifter, GT Grant Steering Wheel, 2.25" True Dual Magnaflow Exhaust System w/ SS Magnaflow Embossed Tips, 700W Rockford Fosgate Stereo System, Lowered 1" Front & Stock Rear, 4.56 Rear with Positraction, 15" Chrome Rims w/ Chevy Center Caps & Michelin Tires, 4.5" K&N Air Filter, Edelbrock 'Elite' Engine Accessories, Chrome Powdercoated Engine Parts
2001 Cavalier Z24, 2.4L DOHC, Silver, Spoiler, AEM Intake, 2.25" Magnaflow Exhaust System, Clear Euro Tails, Tinted Windows, 400W Clarion Stereo System
gkolmatycki is offline   Reply With Quote
Old 09-11-2007, 07:11 PM   #16
mnunn454
mnunn454's Avatar
I like working these equations from the mathmatical side first.
Overall, you'll want about a 10:1 ratio on low (with a normal, say 28-30" tire diameter). With monster tires that are (say 30% taller), you'll want to go to about 13:1 in total ratio in low. (Gear Ratio in low times R&P ratio)
For highway, a 2.8 to 3.0:1 final drive ratio (again with a "normal" tire) is a great target to keep the RPMs driveable at highway speeds. With a 30% larger tire, this should probably be in the 3.73 R&P range (assuming your tranny is 1:1 in high gear).
Sure you can live with more or less than that, but it'll only cause you either fuel wasting or acelleration lacking problems.
JMO.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 09-11-2007, 08:58 PM   #17
theside00
Arent the 700r4 weak and not worth the swap for a 4x4? What kind of add on overdrives are there?
Old 09-12-2007, 12:17 AM   #18
Twistedsteel
Yeah I've heard that they can be weak, but I've also heard that if you find the right year and build it with the right parts that they will hold up but I dunno. Here's the link to the overdrives
http://gearvendors.com/
