Old 09-10-2007, 10:19 PM   #1
Rc 415
Flat Black, & Chrome!
Rc 415's Avatar
What rear end gears should I get?
I've got a 30" tall tire in the back now, and I'm running 2.73 gears with an auto 700R4, I want to accelerate quick, but I'm not sure about what all gears are good for what in the rear, all I know is I am not happy with the rear gears in there now, I cant even chirp the tires, and the truck just doesn't accelerate quick at all, even on the freeway!
1983 Chevy C10 Stepside Sold
http://s69.photobucket.com/albums/i76/rc_415/
Rc 415 is offline   Reply With Quote
Old 09-10-2007, 10:48 PM   #2
slugish
Slugish
Wink Re: What rear end gears should I get?
with a 7004r with 30 in. tires , run at least a 3.73 rear end . should be perfect for what you want. you definitely will do some serious chirping with a 3.73, plus it will be very cruisable. best of both worlds.
slugish is offline   Reply With Quote
Old 09-11-2007, 01:26 AM   #3
xtreme80
Wishin' I had more money!
xtreme80's Avatar
Since you got an overdrive you could even go a little higher than 3.73 if you wanted, but that would probably be the best gear for your ride. Lucky you with overdrive, I'm doing a 3.73 on a 3 speed tranny... haha
xtreme80 is offline   Reply With Quote
Old 09-11-2007, 08:40 AM   #4
Tink
Tink's Avatar
Got 3.73s, 30s and a 700r4 on the 85. She will chirp a tire and pull like a frieght train on the highway. Turns about 2400rpm at 70mph.
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 09-11-2007, 12:37 PM   #5
Rc 415
Rc 415's Avatar
Will this rearend work in my truck? its from a 1990 chevy
http://sfbay.craigslist.org/eby/pts/419084926.html
Old 09-12-2007, 03:08 PM   #6
Rc 415
Rc 415's Avatar
up
Old 09-12-2007, 03:40 PM   #7
jchav62
1962 C-10
jchav62's Avatar
I agree, 3.73's....Especially with an over drive tranny..
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 09-12-2007, 04:58 PM   #8
454HO
I don't know if it will work, but that's a pretty decent price if it's in good shape. Maybe go take a look at it and bring along a tape measure. Check the spring center spacing and the overall width and compare to what's on your truck now.
- Greg
454HO is offline   Reply With Quote
Old 09-12-2007, 04:58 PM   #9
Pyrotechnic
Pyrotechnic's Avatar
I'm not sure on that newer rear end. I asked if I could put an old 12 bolt under a 88-98 truck and was told it would not work so I'm guessing the newer rear end under the older truck wont work either.I would go for a 73-87 rear end.
Pyrotechnic is offline   Reply With Quote
Old 09-12-2007, 05:47 PM   #10
xtreme80
xtreme80's Avatar
I'm willing to bet also that there's something wrong with that rear. Even 10 bolts without ring and pinions still go for more than that around here...
Old 09-12-2007, 08:55 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Anything can be made to work, but that rear end will not just bolt in and it has a much narrower track.
All of the guys above are correct about the 3.73 gears. I have had a quiet a few trucks with 3.73's and they perform much better than 3.42's...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-12-2007, 08:58 PM   #12
Rc 415
Rc 415's Avatar
Thats what I needed to know, thanks I'll keep on lookin and mabye even get somthin with posi.
Old 09-13-2007, 11:25 AM   #13
D13
D13's Avatar
And if / when you swap out the gears (not the whole rear end) mail me your 2.73's. I'll swap them out for my 3.08's behind the 6.2 in the '87 and get up to 24mpg. Since I'm not ever in a hurry (at least not with a 6.2) they'll do me right!
I have 3.43's in my 82 with 30's (14 bolt and posi) and the L6 would happily chirp them, right up until it burned up.
D13 is offline   Reply With Quote
Old 09-13-2007, 11:43 AM   #14
Rc 415
Rc 415's Avatar
If you want to pay shipping no problem, but how would you go about putting them in your self I heard its a very hard task to get them put in correctly.
Old 09-13-2007, 12:05 PM   #15
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
If you use all the bearings and other parts. You can get lucky sometimes and not need to shim anything. But I would still say your money ahead getting a whole rear. Granted the whole rear is a good unit.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 09-13-2007, 12:07 PM   #16
liljon285
That Guy
liljon285's Avatar
Everyone who has had gears has told me to get 3.42...its pretty much inbetween.
1978 Chevy Scottdale Stepside, 3rd engine- 350c.i. built with cam and lifters, holley 670cfm carb. and intake,heads shaved .60. Truck is a project, and I am its restorererer!
liljon285 is offline   Reply With Quote
Old 09-13-2007, 04:29 PM   #17
piecesparts
Parts and more parts
piecesparts's Avatar
I had 3.42 gears with a 700 R4 and they worked fine with the 700R4 on my 84, but I changed over to 3.73 gears when I put in the larger cam and 383 stroker motor along with the 2400 stall torque converter. The 91 pickup that I drive daily has 3.42 gears and a 700 R4, connected to a throttle body fed 5.7 liter motor and it performs well at 20 MPG (the fuel injection throttle body is the trick here). I like the 3.73 gears and the acceleration that it gives me over the 3.42 gears. The RPMs on my different motors are around 2300 RPMs at 70 MPH on the 91 Silverado (29" tires) and the RPMs on the 84 GMC is at 2500 RPMs at 70 MPH. The 3.73 will eat up the 3.42 gears any day of the week, in an acceleration comparison.
My gas mileage in the 84 GMC went from 15.5 / 16 MPG to 14.5/15 MPG average with a 400 HP, 383 stroker motor and the 700R4 tranny. You will like either set, but if you want acceleration and pulling capability, consider the 3.73 gears and believe me the MPGs are not that much different. You can change that slightly by the tire size that you run.
piecesparts is offline   Reply With Quote
