Old 09-10-2007, 10:45 PM   #1
TireSmoke420
One of the few GMC'ers
TireSmoke420's Avatar
converting to hei...87'
so i got a newsed engien from my local junk yard been told its from a 90' anyways has center bolt valve covers and all its sposed to but the guy bfore me put a 2 barrel intake and carb on it with a HEI distributer. now ive been led to believe that the coil in cap heis are better then what came in my 87'. now after i put my old throttle boddie intake on i put the hei dist in but the vac. advance on it gets in the way of EGR and water line on the manifold. what am i doing wrong here i am putting dist. in the same ways it came out and all i dunno what should i do
87' Silverado 4x4
"Young, Dumb And Full Of Cum"
TireSmoke420 is offline   Reply With Quote
Old 09-11-2007, 07:46 AM   #2
Blackstone
Blackstone's Avatar
Re: converting to hei...87'
Your '87 should have already been equipped with a "coil in cap" HEI unit. As far as I know, there hadn't been any significant design changes in these distributors since the 70's. That being said, I guess I'd use the old one if the fit is better.
Blackstone is offline   Reply With Quote
Old 09-11-2007, 08:09 AM   #3
Jim85IROC
Jim85IROC's Avatar
I've used both style HEIs and never found one to be any better than the other. I converted my IROC to a small-cap distributer with no problems whatsoever. But, there's no reason not to use the large-cap style if that's your preference either. Just make sure that you use the appropriate gear for the distributer. Whether your new motor has a roller cam or not will determine whether you use a bronze gear or a regular steel one.
1987 GMC Sierra Classic 3500
454
TH400
My Sounddomain Page
Jim85IROC is offline   Reply With Quote
Old 09-11-2007, 08:24 AM   #4
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
id say use the one that stock from your truck it should be like the one from my 89 that had tbi. using it and your stock intake is it was before wont hart the engine unless like jim said it had a rollers or not ur engine the factory one was not the 90 i dont know, it might have been a vortec engine and i think those did have rollers.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
