Old 09-10-2007, 11:22 PM   #1
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Question rebuild kit????
hey guys quik question, i am looking for a complete rebuild kit for my stock 72 c-10 upper and lower control arms.. i have search all the site vendors sites and didnt find anything, lmc has some things but not a complete kit..... i am doing a frame off...and the suspension is up to bat now... i am running 2 inch coils in the front 2 1/2 drop spindels.<just orderd today. factory front sway bar, new bushings all around... rear i just did a flip kit with shock relocators.... i was thinking about going tubular upper control arms, is this needed? other than it looking cool i wouldnt think i would need them with my front drop? i have had the 2 inch coils now for 7/8 years and with no problems.And adding the spindels wouldnt change anything would it???.. any help would be great. Thanks in Advance ....Tony
bad6772 is offline   Reply With Quote
Old 09-11-2007, 10:51 AM   #2
jlaird
jlaird's Avatar
Re: rebuild kit????
I believe ece has what you need.
jlaird is offline   Reply With Quote
Old 09-11-2007, 01:08 PM   #3
mbgmike
Re: rebuild kit????
Most all of the local parts stores should have everything you need. Do you have a NAPA or anything. We can sell you everyhing you need but you can get it cheaper at a local store almost all of the time. With the exception of the control arms. If everything is ok, are you just wanting to put on tube control arms on your existing setup?
MIke
mbgmike is offline   Reply With Quote
Old 09-11-2007, 09:16 PM   #4
bad6772
bad6772's Avatar
Re: rebuild kit????
mike everything is fine, i just dont know what all i need or the correct terms< dumba$$ i guess, i want to just rebuild them , i am trying to do this frame off right, there are just a few pieces that i m not shure off. i know i want new upper .lower ball joints, but there are a few rubber pieces and a shaft that are on the upper control arms, im not shure what there called, same as the lowers,,, i guess i just need to know what everything is?? and as far as the tubular uppers it was just a pipe dream i guess, my truck rode just find with everything before, and i know that bye just adding spindels that it shouldnt change a whole lot,,, but they would look killer imo, but ill stick with what i got..............
Old 09-17-2007, 11:29 AM   #5
jasonb72
PorterBuilt Man Crush
Re: rebuild kit????
I have an ECE complete front end rebuild kit minus ball joints F/S over in the 67-72 parts section. Check it out
The 72 will live again
jasonb72 is offline   Reply With Quote
Old 09-17-2007, 02:42 PM   #6
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: rebuild kit????
Keep me posted on this kit.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-19-2007, 04:05 PM   #7
OLDIRON69
Re: rebuild kit????
LMC has the lower control arm seal, but they only have the 3/4 ton upper control arm seal. I have looked everywhere for the upper with no luck. My shafts show NO wear so I didn't want to buy the shaft kit but it looks like I will like it or not.
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
