Old 09-11-2007, 08:58 AM   #1
jc1969c10
jc1969c10's Avatar
Exclamation Three On-The-Tree Problem
First of all, I must say that I am glad that I found this site. The replies and the post that I have read through are great!
I have a problem with rebuilding my column. The two shifter bolts/pins are hitting each other. I replaced the old column with a used one. After taking it apart and cleaning and re-greasing, I was reinstalling and the two shifters want to collide. I have the spacer between the first and second shift arms but the bolts/pins still hit each other. I thought I was careful to keep track of all the parts and the assembly order, but I may have missed something or something was missing on the column I bought.
Any suggestions?
P.S. I have tons of picks from my rework of my '69 Step-side but I am at work and don't have them with me. Will post some later.
jc1969c10 is offline   Reply With Quote
Old 09-11-2007, 09:58 AM   #2
Putter
More Cowbell....
Putter's Avatar
Re: Three On-The-Tree Problem
Try and get a close-up pic of the parts that are touching.
Someone will be able to point out the issue pretty quickly adn most likely even post up a photo of what it should look like.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 09-11-2007, 10:06 AM   #3
rckendal
Welcome, I don`t have a answer for you but seen where you are from and I live in Buena Vista about 50 miles from roanoke. I also have a 1969 c10 step side, I plan on coming up that way on the 22nd to salem to a show there maybe i will see you there, also this site has help me in so many ways that i cant thank these fellow Chevy truck lovers enough.
rckendal is offline   Reply With Quote
Old 09-11-2007, 11:11 AM   #4
northerngmc
northerngmc's Avatar
I can't quite visualize what your problem is either.
Welcome to the board, yes it is a wonderful resource.
If you haven't already looked there is a FAQ(Frequently asked question) Section http://67-72chevytrucks.com/vboard/s...d.php?t=157669
And a great thread called "3 Speed Manual Column Shifter Adjustment " located here http://67-72chevytrucks.com/vboard/s...d.php?t=215307 with great pictures. I would suggest reading this. I did when I was installing and adjusting my 3 speed column.
Good luck and please post back again and let us know how it is going.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 09-11-2007, 03:55 PM   #5
jc1969c10
jc1969c10's Avatar
Hey Guys,
Thanks for the quick help. I found the problem. I tool the column back out and put it side-by-side to the old one. The collumn that I bought has a straight link behind the ****ft engagement lever. My old one has a bent one, so it seems that someone took an automatic at some point and turned it into three on-the-tree.
My plan now is to disassemble both and and build one. I've already found out that the shift cover (inside the cab), is built slightly different but I'll get it to work.
I'll post an update with pics when I'm done.
Old 09-11-2007, 08:01 PM   #6
Orange Truck
Orange Truck
I am interested in your problem as some of the information submitted may be useful to me as well concerning my C10 Stepside and a "three-on-the-tree" shifting problem. It locks up at times and I am unable to shift to anything until I get out raise the hood and move two "arms" into alignment(probably the wrong term) near the firewall. Obviously something is worn either bushings or the shifter levers. Where can I get the bushings or shifter levers, and parts if that is what is needed? I went to a large local Cheverolet dealer and the parts man made me a photocopy of the whole steering column and parts by an item number (not the identification part number) from an old book there.Help.
Orange Truck is offline   Reply With Quote
Old 09-11-2007, 10:51 PM   #7
northerngmc
It may be out of adjustment. Try adjusting it as shown in this article, http://67-72chevytrucks.com/vboard/s...d.php?t=215307
It is simple and can be easily done with the column still in the truck.
Blaine
Old 09-11-2007, 11:00 PM   #8
jc1969c10
jc1969c10's Avatar
Orange Truck:
Something else to look at, is the bushings. On the arms, that you have to move aroung, there are two bushing that are supposed to be in the linkage where the rod comes through. It is a rubber bushing and also, has a metal sleeve in it. I had a lot of slack in mine and didn't even realize there was supposed to be rubber in this linkage.
Another wear spot for the shifters is down on the side of the tranny. These linkages also have bushings. You might check these as well.
Old 09-11-2007, 11:02 PM   #9
jc1969c10
jc1969c10's Avatar
Oops. I meant to give you this link. It comes from the thread that NorthernGMC posted.
http://www.classicchevy.com/product....4&dept_id=1889
These are the bushings you need. I think they fit both the upper end and lower (tranny) end.
