Old 09-11-2007, 10:12 AM   #1
semperfidoordie
Fix It Till It's Broke
semperfidoordie's Avatar
Antifreeze in my valve train
Hey,
I was wondering what would cause antifreeze in my valve train and down to the spark plugs? Could it be a simple intake gasket or do you think worse?
Tony
Black Beauty: 85 C-10 SOLD!
Great White: 69 LWB Custom Camper/20 SOLD!
Blue Dragon: 72 K-10 SOLD!
The Tank 77 K-10 KIA
panhandler62: Just don't search for "trannys" no matter how hard yours shifts -- you just won't get what you are looking for.
I Made The Official So Cal Board Meet
semperfidoordie is offline   Reply With Quote
Old 09-11-2007, 11:20 AM   #2
Scott68-93-97
Scott68-93-97's Avatar
Re: Antifreeze in my valve train
Intake manifold gasket is a possibility, but down to your spark plugs sounds like a cracked head
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
Old 09-11-2007, 11:55 AM   #3
cdowns
cdowns's Avatar
could be inteke or head gaskets or heads themselves
Old 09-11-2007, 11:55 AM   #4
grayw0lf
You're probably best to pull the heads & inspect. That way you can see if its the head or the gaskets. You probalby have a nice milkshake in your oil pan.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 09-11-2007, 12:01 PM   #5
jay6891
Car Knocker
jay6891's Avatar
A friend of mines 442 was doing that right after an engine rebuild. Head gasket had blown filling the cambers up with antifreeze and on the compression stroke it would push the antifreeze past the valve guides and, well you know the rest. I TOLD him to quit harrassing the machine shop about his engine, kinda like pissing off the cook. Don't know what your gonna get.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 09-11-2007, 12:04 PM   #6
prg machine
prg machine's Avatar
Best to dump that oil right now and cure the problem. Anti-freeze will take out a set of bearings real quick.
prg machine is offline   Reply With Quote
Old 09-11-2007, 12:17 PM   #7
Worst thing is hydo-lock.Let a combustion chamber fill and go to start.On compression stroke it can bust a piston or bend a rod.Don`t run it until pulling the heads and remedying the source.It`s Russian Roulette.
Old 09-11-2007, 02:08 PM   #8
prg machine
DUMP the oil! You might luck out. My buddy had a manifold gasket changed at a shop. They didn,t change the oil. Rod bearing let go within 25 miles. GM dealer tore into the bottom end and every bearing was toast. Said it was anti-freeze.
Old 09-11-2007, 03:24 PM   #9
semperfidoordie
yeah it's not a daily driver right now anyway...just gotta figure out how to get it to the shop without driving it
Tony
Old 09-11-2007, 03:28 PM   #10
Scott68-93-97
is there antifreeze when you pull the plugs if so Im puttin my money on the intake, but either way dont start it
Old 09-11-2007, 03:35 PM   #11
semperfidoordie
yeah when we pulled the plugs the antifreeze doesn't run out but the plugs look wet with antifreeze and smell like it...
Tony
Old 09-11-2007, 09:31 PM   #12
Pull the plugs and crank it out,at least for now.
Old 09-12-2007, 10:30 AM   #13
semperfidoordie
like pull the plugs and then try and start it to push all the antifreeze out?
Tony
Old 09-12-2007, 10:46 AM   #14
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I think that is what he is referring to, does not want the antifreeze to damage
the motor.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 09-12-2007, 10:47 AM   #15
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Yep! Thats the idea.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 09-12-2007, 10:56 AM   #16
63 & 64 Bowties
and a few others
pull the plugs and WITHOUT PUTTING THEM BACK IN, crank it to blow out the antifreeze.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 09-13-2007, 09:36 AM   #17
semperfidoordie
okay..I know that sounded dumb haha sorry...i just wanted to make sure that like turn the key and start it like normal was what I was supposed to do. I'm a newbie to this whole truck working on myself thing...haha...thanks for all the help. I'm going to give that a shot this afternoon after work and see if that helps...Can I pull the intake and look at the gasket without taking the motor out again?
Tony
Old 09-13-2007, 10:30 AM   #18
Scott68-93-97
yes, no need to pull the motor
Old 09-13-2007, 01:49 PM   #19
semperfidoordie
sweet cause here on base we have a hobby shop that's open everyday except monday but keeping your motor on a stand is $5 a day but combine that with bills and trying to find a place to live in San Diego for my wife and I it adds up haha...i'm trying at all costs to not sell the truck and to fix it without pulling the motor...cause if not it's for sale right now if I can't get it fixed and get a decent offer i'm selling it
Tony
