Engine swap to Big Block VS Small Block
Hi,
I just wondering about going with a big block 454 instead of a 350. A guy I know is selling an engine that pushed a 64 chevelle to 11.88 in the quarter. Anyway, he returning the car to stock and selling the drive train and I'm thinking of buying the engine and putting it in the C10 when I done. Anyone have any suggestions or comments, good or bad regarding this swap?
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
1971 GMC 3/4 ton, 572 CID
Re: Engine swap to Big Block VS Small Block
Go for it, big blocks rule!!!!
71 GMC 3/4 572 CID, 1988 GMC 1/2 2006 Saturn Vue "We always have parts left over on a job this size" |
Junior Member
Just be sure to add up everything that will have to be changed. There is more than you think. I changed an 81 El Camino from a v6 to v8 when I was 17(20 years ago) and I am changing the 72 swb from sb to bb. I won't do it again. Just my .02cents.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
no question for me -- big blocks rule as long as fuel mileage isnt a consideration
If your truck is going to be a daily driver i would leave that 350 in it. Unless you are rich or are just going to use the truck in the weekends go for it. But me i regret
Definitely!!! Yes there are several conversion considerations, but IMO WELL worth the investment in the long run. Fun factor will even outweigh fuel factor (unless this is your 50+ mile daily diver.) Just one 200 foot burnout with that 454 will infect you forever! ![]() No going back for me. ![]()
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
