![]() Join Date: Aug 2001
Stepside Bed
Question what do you use to seal between the step fender and bedside, I know that they have that felt rap stuff but originally they just used sometime like caulking from the factory. Can I use some a small bead of clear silicone will that work?
Thanks,
DREW67 Last edited by DREW67; 09-11-2007 at 06:00 PM. |
Re: Stepside Bed
I've got some rust there along the edge of the fender and the guy that's going to paint it[whenever I get that far] wants to use stuff he calls Metal To Metal, says it's the best. A little pricey but well worth it.
Old Skool Club
![]() Join Date: Jun 2001
Re: Stepside Bed
I preach on this stuff, but you should be careful about the silicone you use on any metal surfaces. Make sure the stuff you use is for automotive applications. If not, you will find that it causes rust where it comes into contact with the metal. I can say this because we used RTV extensively where I worked, and a bunch of it was used to paste ISO instructions to steel columns of the buildings. It WILL cause rust.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Re: Stepside Bed
I have seen black door edge guard used and it looked very nice.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
upgrading to an older model
Re: Stepside Bed
I saw in one catalog they sold "Fender Welt". It was a leathery/plastic gasket (for lack of a better word) that went between the fender and the bed side. I can't remember which catalog though.
68 stepside, short-box, multi-colored (for now) ![]() ![]() ![]() |
i love summertime
Re: Stepside Bed
here is a shot of the rubber piping im using....i got it at a volkswagen restoration shop
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
Re: Stepside Bed
I've also been told many times never to use silicone. I like the piping idea. one day when I have a million bucks I would like to weld and get rid of all the seams
"spiiiider pig, spiiiiider pig, does whatever spiiiider pig does. " |
Nothing to see here.....
![]() Join Date: Jun 2007
Re: Stepside Bed
Andrew,
I didn't know you coming over to work on my new (your old) truck. That's so nice of you!!!! Sorry to hijack the thread, back to the subject....... |
Re: Stepside Bed
Doug man you can always bring it back. I always get sad when I see them drive off and it looks good to. I'm glad your enjoying it. I will need some help moving the bed over to the frame so you can come help me buddy...
DREW67 |
Re: Stepside Bed
My thing is guys I don't like the look of the felt around the fenders on some trucks. If your truck is black it would look ok but your truck is red I think it would stand out. Any more suggestions?????????
DREW67 |
Designated A-hole!
Re: Stepside Bed
The fenders that came with my truck (they were removed when the truck was new to install tool boxes) had a putty like substance that looks a lot the stuff the electricians in the Navy used to call Monkey $h!t to seal wires going into pecker heads. A gray putty that is water proof and doesn't harden or set up.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" Last edited by krue; 09-12-2007 at 12:36 PM. |
![]() Join Date: Nov 2004
Re: Stepside Bed
I don't think it stands out, blends in with the truck. Most people never notice it.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#13 |
Designated A-hole!
Re: Stepside Bed
I think it stands out personally, nothing against you or your truck, it's a very nice truck, but when I put my bed back together I'm either gonna find some of the putty I mentioned above or something similar.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" Last edited by krue; 09-12-2007 at 07:34 PM. |
#14 |
![]() Join Date: Feb 2001
Re: Stepside Bed
Krue, did you think mine stood out? Honestly it won't hurt my feelings. I always sorta thought that it wasn't that noticable. It is a pain to install the fenders using that stuff.
#15 |
Re: Stepside Bed
The welt doesn`t do anything to help seal.It`s not a bad idea,but won`t seal the gap.There should be no gap anywat.Just a seam.The factory used seam sealer.Silicone is also bad because paint won`t stick to anywhere it`s been,including where you wipe off excess.Jim Carter sells the welting.I`d still use a sealer on both sides.The best thing to do is seal it so nothing can get between there in the first place.There`s a urethane tripolimer caulk for window glazing called Geocel I use in my siding business.It stays pliable and won`t crack,paintable,and works to bond real well.I`ve used it on my utility beds at the seams with great results.You have to finger it as soon as you lay it on,skins right up.Sealing from underneath is the big issue here for rust prevention.
#16 | |
so easy a caveman can do it...
![]() Join Date: May 2006
Re: Stepside Bed
...takes notes on thread. Put Monkey Sh*t on list, hmm....might need to pick up a dozen pecker heads. *thinks to self* Is there anything else? ![]() ...workin' on half a cup of coffee...goin' back for more. |
#17 | |
Re: Stepside Bed
![]() The fender welt was easy to install. You have to slit it and cut out triangle sections in the curves and I used a spray on adhesive to put it on the fender, then just bolt the fender to the bed. I put it on the truck back in 97 and pulled the old stuff off last year when I redid the truck. There was surprisingly no rust where the welt was. I actually thought there would be....
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 09-13-2007 at 09:50 AM. |
#18 | |
Re: Stepside Bed
On mine...I don't have the truck painted yet so I taped off where the outline of the fender is, painted it with that rubberized undercoating stuff, painted the Flange on the fender where it touches the truck with the same stuff then bolted it on. I figure two rubberized coated surfaces should seal pretty well and if its painted rust shouldn't be that much of a problem.
68 stepside, short-box, multi-colored (for now) ![]() ![]() ![]() Last edited by Brock; 09-13-2007 at 11:36 AM. |
#19 |
Designated A-hole!
Re: Stepside Bed
Randy I noticed the welting on your truck, it didn't look bad, but I think it could look better. I've used the welting before and didn't like the way it looked on my truck, so now I pay attention to other stepsides to see what's being used, which is probably why it stands out to me.
BTW a pecker head is the box where wires enter and leave a motor or generator. ![]()
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
