truck just started popping through the carb and hesitating really bad... checked and rechecked the timing before this happened and everything was running perfectly... went for a 20 mile trip(yes, that says 20) and about 3/4 of the way there the truck started acting up... had to leave it parked for fear of a breakdown...
any ideas why it would start popping through the carb and hesitating? edelbrock 1904 on edelbrock performance intake, 350 engine... |
Re: popping though carb out of nowhere!
Mine did that when it wiped a cam lobe.
- Greg |
that doesn't sound promising... any more common ideas first? need to move truck asap...
You would probably notice if you had one, but my holley did the same with a good size vacuum leak.
79 Jimmy slammed AKA James Down |
hmmm... push rods... wish i could find my rocker adjuster tool(s)... went to the parts store the other day and nobody even carries them anymore...
i might end up selling the damned truck VERY soon... seems like every time i fix something, something else goes off it's nut... thanks guys... any other ideas, i'm listening... |
The Crazy Machanic
mines been doning that i think it a need of a new cap and rotor cause it not doing so hot. But that not a big deal anymore cause i have to take the motor out now.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) ![]() * 1970 chevelle 2dr sedan Latest update June 24 2007. ![]() *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) ![]() newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one ![]() |
Do a compression test. You can borrow a gauge from Autozone.
- Greg |
STILL PLAYS WITH TRUX
Well i think everyone is going to big to fast you said you made some timing adjustments BEFORE this happened.
Sooooooo i'd look at the distributor and see if it came loose and moved throwing the timing out. Also check all connections to the dist. and all vaccum connections make sure that the ign. wires arn't touching the headders or manifolds and grounding out. Check all the basics first then if you can't get the truck to run smooth then pop the valve covers off and look for any obvious damage bent pushrods or broken intake valve and exhaust valve springs. If that looks good have someone turn the truck over while you make sure all the valves are actuating. If that looks good then check your mechanical timing by bringing #1 to TDC and see if the dist. rotor is in it's correct phase. if not correct as necessary. If the truck is still not running right pull timing chain cover and check the timing gears and chain also recheck the mechanical timing and see if the cam and crank are in time with #1 @ TDC. If no problems are found by now then i'd say pull the cam and visually inspect it for any obvious defects. Good luck. |
'Burban Legend
![]() Join Date: Apr 2005
You definitely want to check all the external stuff FIRST, but more than likely you probably have a flat exhaust lobe on the cam, or a stuck, burnt or bent exhaust valve. Hope it is just a crossed wire or a loose or damaged upper valve train component. The cracking sound is usually caused by exhaust gas that is not able to escape via its normal route. Good luck to you, Mike
'67 Chevy Iron City Beer Truck (9ft step) '67 Chevy Panel Truck 467 '68 Short Fleet 305v6 '68 McLaren Ramp Truck '68/'68/'70/'71 Burbs 292/366/402/454 '69 C-30 dump '71 C-50 dump and church bus '71 4x4 454 '72 Blazer (w/pop-up camper) $15 x-hooks '66 Chevy II 194/Weber '68 El Camino" 305v6 '69 Skylark 455 Buick '70 Chevelle 427 '71 Cutlass W-31 '71 GTO 400 2x2 "The 51" Chopped '51 Chevy (409) my first car OK Toad, we'll take 'em all... John Milner |
Another very simple check - remove the oil filter, cut it open and check for metal. May not be 100% conclusive, but if a cam lobe is worn the metal has to go someplace.
- Greg |
What year of truck? Do you have point or electronic Hei ignition? If points they could be burnt of worn throwing off the dwell and timing. This happened to me years ago with a dual point distributor. Tore into the timing chain and replaced it thinking it jumped a tooth or two. It was only the dwell difference between the two sets of points that was throwing everything off.
Hope you find the problem and it's an easy fix. God Bless, Terry ![]() |
#13 |
Stepside Fanatic!
![]() Good luck! |
#14 |
![]() Join Date: Oct 2006
I had a similar problem a few years ago, it would run ok for a little bit, then start popping and hesitating. It was as simple as a cracked distributor cap. I assumed the worst at first too, but started eliminating the easy stuff first. With a flat lobe, or some of the other suggestions, wouldn't you hear it hammering at higher rpm, or making noise in general?
#15 |
![]() Join Date: Jul 2007
sounds like a cam lobe - unplug one plug at a time -if you get it to stop then I'm pretty sure that's the issue. It's happened to me 2x's!
#16 |
In the Forgotten far North.
Double check yor plug wires too. You may have gotten a couple crossed up when you did the tune up.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
