Old 09-12-2007, 07:00 AM   #1
syncrov69
syncrov69's Avatar
8 bolts to 5-6 bolts wheel?
Is it possible to convert 2500 8-bolts wheel to 5 or 6 bolts without changing major parts. Wheel adaptor, drive shaft? What is your trick to make the conversion if it's possible? Thank's
syncrov69 is offline   Reply With Quote
Old 09-12-2007, 09:15 AM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: 8 bolts to 5-6 bolts wheel?
Here is an adapter. Without swapping suspension your options are limited.
http://www.skulte.com/product_info.php/products_id/78
sneakysnake is offline   Reply With Quote
Old 09-12-2007, 10:07 AM   #3
syncrov69
syncrov69's Avatar
Thank's, it's very expensive but your solution is very good.
Old 09-13-2007, 05:15 PM   #4
68K20 x Drill
SS454's and heavy halfs around 1990. sometimes have a Corporate semifloating 14 bolt with 5 lugs.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 09-13-2007, 05:57 PM   #5
Scott68-93-97
Scott68-93-97's Avatar
With 6 lugs in light duty 3/4 ton trucks from 73-87 and 88-94
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
Old 09-13-2007, 05:58 PM   #6
Scott68-93-97
Order some axles in whatever pattern you want
