09-12-2007, 02:26 PM | #1 |
Terminal Block
Where can I get a terminal block similar to this one (http://www.madelectrical.com/catalog/cn-1.shtml). I would buy the one at madelectric, however, the line is ALWAYS busy and I simply cannot sit around the phone trying to get through. Anyone have alternatives to the terminal block in the link I posted? THANKS!!!
09-12-2007, 02:44 PM | #2 |
its all about the +6 inches
Re: Terminal Block
bad link
09-12-2007, 02:57 PM | #3 |
Re: Terminal Block
Thanks for catching that!!
09-12-2007, 03:24 PM | #4 |
Re: Terminal Block
I would just grab one in the junk yard. Square body S-10's have them, as do MANY other GM vehicles. |
09-12-2007, 06:03 PM | #5 |
Re: Terminal Block
GM fullsize 1990+ trucks have a nice 5 or 6 terminal distribution block located on the firewall under the relay cover. It's my personal favorite.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
05-20-2008, 10:42 PM | #6 |
Re: Terminal Block
Mad Electric doesn't answer the phone no matter how long you let it ring. But i finally found a company with a single post "power block". I did I know to not call it a terminal block. They also have dual ones and the bus bar, etc.
www.delcity.net
1972 chevy custom K20 though registered as 71 when CHP found VIN on the frame. |
05-20-2008, 11:01 PM | #7 |
Re: Terminal Block
Summit or Jeg's has a single post block. But if your planning on putting it near the battery check into a battery terminal at a local car audio shop. I think Wallyworld even carries them. I bought one from an audio shop that has 2-4ga, and 2-8ga holes,and uses set screws to secure the wires. It's even gold plated. I think it cost me about $15.
Or like others here said, and anyone else I asked when looking for an accessory block, go to a wrecking yard. They're everywhere, and dirt cheap. Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! |
05-20-2008, 11:18 PM | #8 |
Re: Terminal Block
I like these, one hot in & that way you can add the fuse you need too. Got mine at OReily's for about $15.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
