Project '66...
Hey guys I'm pretty new on here - been browsing for a while. I picked up this '66 short stepside on ebay a couple months back and it arrived into the UK a couple weeks ago. I have always been a VW guy and own my own shop doing VW suspension modification, but have always admired these 60's trucks. I always wanted a short fleetside, but when I saw this with the original paint and the tire mount I fell for it. I have a real thing for faded original paint and lowered suspension.
![]() ![]() Plans are to buff out the paint, do the metalwork, then blend with a color match and swap the badly dented rear fender for the better one that came with it. Then drop spindles and disc brakes, maybe some 2" blocks for the rear and a c notch. I guess I got lucky, as the suspension is already lowered on coils, but I don't know how much. It has an adjustable rear track bar and shock relocator kit installed. I plan to do some logos for my shop on the doors when it is done and use it to tow VW buses from Europe and the docks on a trailer. I also need to find a nice stepside rear bumper, as I can only find suppliers for chrome ones. Maybe I'll turn up a good used one..? These are the pics of the day I collected it from the shipper. ![]() The bed had been repainted at some point in a similar color to the original, fortunately this sands off easily with wet 400 or 600 wet and dry. Here I have exposed the original paint underneath ![]() I have been removing the flames and door logos, but they must have used house paint or something, it won't come off unless you sand it and takes the original paint off underneath. I painted the Chevrolet on the grille in black as original and have been wet sanding with 2000 grit and buffing the paint. It is turning out awesome. All this is until I can let my wallet recover and order some parts and panels. It needs 1 outer rocker, both front fender rear sections, 1 outrigger/floor support and some door repairs. Apart from this it is rust free. I plan to powder coat the stock rims black and fit thin band whitewall radial tires. Anyone know a supplier for these? ![]() ![]() |
Still Truckless!
Re: Project '66...
Looks like a good start. Good luck.
~James ![]() ![]() 2009 Hyundai Sonata<~~Wife's sedanomatic 1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive ![]() ![]() ![]() ![]() |
![]() Join Date: Oct 2006
Re: Project '66...
Cheers from this side of the pond ! The tyres should be fairly easy to find. Keep us posted
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
64-66 CHEVY JUNKIE
Re: Project '66...
Good original find, good luck on your project.
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E ![]() ![]() |
Re: Project '66...
looks like you got a good find good luck
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN 62 HARDTOP NOVA 65 CHEVROLET BB LWB FLEETSIDE 90 CHEVROLET EXTRA CAB CHEVY ONLY - NZ Chapter http://67-72chevytrucks.com/vboard/s...d.php?t=137984 |
and a few others
Re: Project '66...
not sure if they'd have what you're looking for, but have you tried Coker Tire? www.coker.com
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
Between the earth and the sky
Re: Project '66...
Looks like a great truck, and you have all your plans laid out! Welcome and good luck with it!
Chris - 1966 C10 Shortbed Fleetside, 1991 GMC Sierra 1500 Extended Cab, 1993 Blazer Sport 4x4 My other rides: 1969 Chevrolet Impala SS427 Convertible 1976 Dodge Tradesman B200 2002 Nissan Maxima 6 speed 2004 Mercedes Benz CL500 |
Re: Project '66...
nice truck, looks like a good place to start from... good luck
John
Respect: 1. A feeling of appreciative, often deferential regard; esteem. 2. The state of being regarded with honor or esteem. 3. Willingness to show consideration or appreciation. When you fail to show consideration to others values you are showing disrespect. |
Re: Project '66...
Wow, thanks for a great welcome!
I checked coker's website before, but couldn't find what I am looking for. I know I have seen them on other trucks, so I'm sure they are out there. I thought about using portawalls, but they never seem to sit right and I would have to buy 2 sets to include the spare tire. I started knocking the dents out of the spare drivers rear fender tonight with a hammer and dolly. I'm far from a professional at panel beating but it is coming out pretty well. I have roughed out most of the large dents for now. I think I will bare metal it to finish getting it straight, as I don't want to use ANY bondo on it. I figure if it has a couple small imperfections it will go with the truck. Bit of a ****ty before pic, as it is the ebay one. It had dents all along the upper curve including the ones you can see at the upper rear corner. It also has a crease on the lower rear side and the arch lip has been tweaked a little and split. There is a little rust at the front edge which I will repair, but it is very saveable, especially with the prices of rear fenders being so high. It is also MUCH better then the one that is on there, which is pretty badly dented and has a load of cracked bondo ![]() |
Re: Project '66...
the truck is looking great, good luck to you,
Re: Project '66...
nice truck good start
1966 chevy c-20 truck " La Chata " under construccion ![]() ![]() ![]() |
Re: Project '66...
Thanks for the replies. I worked a little on the spare rear fender today. There was some rust in the lower front corner, so I bare metalled it, then cut out 2 pieces and butt welded in 2 small patches.
Before: ![]() During: ![]() After: ![]() The pic is not great, but it looks good. With a little bit more grinding and maybe a little lead or a tiny skim of filler it will be perfect. I then bare metalled the upper rear corner, as this had a stubborn deep dent about the size of a fist and lots of other small dents. It took a little while, but the big dent is gone and perfectly smooth and the smaller ones are almost there. ![]() I am pleased with the progress so far, hoping to have it bare metalled and straight in the next couple of weeks. Unfortunately I have a hell of a lot of work on at the moment and I have to do a weeks training for the programme my little boy is on, so I am working the weekends to try and catch up. Last but not least, I added a couple of vintage decals I got to the rear window.. ![]() |
#13 |
New Member
Re: Project '66...
Great truck to start out with. Looks like you have things well underway. Funny you should mention your a VW guy, I just got a 73 Karmann Ghia a couple of weeks ago. Maybe we can trade info on each others projects.
1961 GMC 1/2 ton long stepside 2002 Chevy Silverado 2500 4X4 HD 1979 Chevy Z/28 2003 Chevy Monte Carlo SS Isaiah 40:8 "The grass withers, the flower fades, but the word of God stands forever." |
#14 |
Re: Project '66...
Wow, that truck is my twin, its even the same color. What motor does yours have? Mine has been replaced with a 350 and a 200-4R tranny.
IMHO if you are going to replace that fender, why not get one without the spare tire, er, tyre cutout. I think it looks better with round fenders and usable step sides. They use the same rear fenders from 55-66. The only disadvantage is if you add a rear fuel tank then you have to throw your spare tyre on top of the load like below. Here are a couple parts links for you http://www.classicparts.com/ http://www.lmctruck.com/index.htm Last edited by Tomsriv; 09-18-2007 at 11:41 PM. |
#15 | |
Re: Project '66...
#16 | |
Re: Project '66...
