Old 09-12-2007, 09:34 PM   #1
jkade
jkade's Avatar
LS1 motor mount brackets?????
I made my own conversion brackets that are like the s&p style. Question is, the factory three bolt mounts that I took off a 86 350 had a plate between the block and the mount and the mount has a hump that is on the back side of it ( the hump sits inside the plate that is between them). So if I don't use the plate the mount will not sit flush on the brackets I made, if I use the plates will the mounts still bolt into the towers or will they be spaced to wide to get the 2 bolts in? I hope this makes sense
jkade is offline   Reply With Quote
Old 09-12-2007, 09:47 PM   #2
BustedTruck
BustedTruck's Avatar
Re: LS1 motor mount brackets?????
I purchase mine from Classic Performance Products. They have a slot cut into them that the raised rib on the mount sits in. I dont know what needs to be done to the S & P mounts.
BustedTruck is offline   Reply With Quote
Old 09-12-2007, 09:49 PM   #3
jkade
jkade's Avatar
Is there a mount the doesn't have the raised rib?
Old 09-13-2007, 01:24 PM   #4
jkade
jkade's Avatar
bump.ttt
Old 09-13-2007, 03:23 PM   #5
shifty
Questionable
shifty's Avatar
*bump* for you.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 09-13-2007, 04:06 PM   #6
jkade
jkade's Avatar
I guess it is going to be trial and error. I will try it with the plates and if it wont work I will cut my plates so it will sit in there flush.
Old 09-13-2007, 06:28 PM   #7
shifty
Questionable
shifty's Avatar
I'm really curious to see what you end up with. There are three different mounts for our trucks - BBC, SBC and inline 6. I think they are all distinct. There is a thread here which explains how to convert one of those into GenIII mounts (i think the SBC mounts are the ones). The article is in the FAQ i think - and I believe the poster's name was 'rolphe1' or something similar that started with an R.
The GenIII ECE mounts I used look like 78-87 engine mounts (or 73-77?) that just have the top half of a F-Body mount bolted onto them. You could probably make the same mount for around $100.
I really wish someone here had a definitive answer...but ...
Old 09-13-2007, 08:52 PM   #8
jkade
jkade's Avatar
I am using the mounts and towers off a 85 or 86 2wd truck. I will let you know if they work.
Old 09-13-2007, 09:35 PM   #9
BustedTruck
The mount plates I purchased came with the rubber mounts with the rib, but I wanted the poly mounts & they have no rib. Not sure if this will answer your first question, but hope it helps.
Old 09-13-2007, 09:37 PM   #10
jkade
jkade's Avatar
Those are totally different than what I am using. Thanks for trying though
Old 09-13-2007, 10:06 PM   #11
billyjo
Junior Member
billyjo's Avatar
I'm using the S&P mounts and mine don't have the slot in them. They bolt flat with a bolt going through the tower into the mount very similiar to the picture above on the left (gold anadized).
I know there is a difference between the 4x4 mounts and the 2x4 mounts so the way mine mount may not be applicable.
Good thing I went out and looked because mine was loose.
1972 K/5 4x4, Radixed LS1 6.0, 428HP/445TQ, Lingenfelter GT2-3 cam, WCCH 90mm J-Tube, LS2 90mm TB, Stainless Works Headers, NV4500, 4.56 gears, Detroit Lockers, 14 bolt FF, Dana 60, 4 wheel disk Hydro Brakes, dual electric fans, Autometer guages, 4" lift, Zero Rates, Weld Evo Velocity XT8 wheels, 35x12.5x17 Super Swamper SSR's.....
http://s72.photobucket.com/albums/i1...tos/?start=all
billyjo is offline   Reply With Quote
Old 09-16-2007, 07:41 PM   #12
jkade
jkade's Avatar
I ended up using the stock 67 mounts. The towers off the 85 would not work so I used what I had. I got the motor and trans in and about 75% wired up. Maybe it will run by this time next week.
Old 09-17-2007, 12:33 AM   #13
Americanrider
http://www.classicperform.com/tech_a...ngine-Swap.htm
Americanrider is offline   Reply With Quote
Old 09-17-2007, 11:47 AM   #14
shifty
Questionable
shifty's Avatar
Man, classic performance needs to update that page, it's pretty dated and single-sighted at this point.
