Old 09-12-2007, 10:35 PM   #1
Rokcrln
Rokcrln's Avatar
ECE's Cup Holders!
I do not know if this has been covered or not so I did my usual while installing mine. I stopped by ECE last time I was down in Fresno and saw this for the first time and thought it would be a great addition to Low Buck (since I don't smoke).
It was $55 and took all of an hour and a half to install. I do not know if they have these parts made or if they are a factory unit for some other vehical and they just make the mounting plate for our truck. Ether way it is a great piece that is of factory quality noit some flimsy unit like we have all seen before with other parts like this. Their instructions are good but in black and white so I thought while I was at it I would do my own version.
1) First thing is to remove your AC/Heater control panel and then your Ash tray. Mine had 4 screws holding it in but some may be spot welded (according to their directions) and you will need to follow their directions for this.
2) Unpact your parts and you will find every thing you need for the install.
3) You need to drill out the pop rivit that holds on the face of the ash tray.
4) Mark and cut the old mounting lip off as shown and then bend up the two tabs on each end.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 09-12-2007, 10:41 PM   #2
Rokcrln
Rokcrln's Avatar
Re: ECE's Cup Holders!
5) Next is to clip on the new backer plate that will hold you door in place.
6) It slide over a notch from the top and then you flip it over and add 2 clips to secure the plate to the slid out cup holder.
7) Once that is done you simply clean the inside of your old door real well (I sanded mine and used a wax and grease remover) and stick it to the door mounting plate with the double back tape that comes already on the plate.
8) Then bend the tabs over the mounting plate and you are done with this step.
Kevin
LFD Inc.
Old 09-12-2007, 10:47 PM   #3
Rokcrln
Rokcrln's Avatar
9) Then take your bracket that came out of the truck in step one and mark it and cut per the directions supplied in the kit.
10) After that you will cut out the two templets provided and mark the mounting holes in your bracket. Care must be taken with this step to make sure it lines up corectly once it is installed back in the truck.
11) The last step and the hardest is to re-install the modified bracket back into the truck and with your glove box removed used a mag screw driver and install the 4 supplied screws.
12) Replace the glove box, AC/Heater controll and give it a try.
Mine worked great and should help keep my water from rolling off the seat and dropping between the passenger door just when you want a sip.
Kevin
LFD Inc.
Old 09-12-2007, 10:48 PM   #4
Rokcrln
Rokcrln's Avatar
And the finished product!
Kevin
LFD Inc.
Old 09-12-2007, 10:57 PM   #5
samwise68
FarmBoy.
samwise68's Avatar
that is a class act!
i've seen the ones that just stick into the hole after removing the ash tray, but not one that uses the original face plate.
thats is definitely something to look into, in my opinion.
thanks for the write up!
-Sam.
1969 GMC C1500. long fleet.
307. 3 on the tree. 3.07 gears.
Oliver green. Bent and bruised. Daily Driver.
Screw patina... it's a beater...Beaters are cool.
my build thread - Project Homebrew:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993
samwise68 is offline   Reply With Quote
Old 09-12-2007, 11:04 PM   #6
Frizzle Fry
Frizzle Fry's Avatar
I love those!
Frizzle Fry is offline   Reply With Quote
Old 09-12-2007, 11:29 PM   #7
lpaine
lpaine's Avatar
I've been waiting for someone to come up with one of those, looks good! I may have to buy one for the 69.
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 09-13-2007, 12:17 AM   #8
70cst
70cst's Avatar
Ok...Maybe its getting late but I was not able to find this in the ECE site?
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 09-13-2007, 12:21 AM   #9
Rokcrln
Rokcrln's Avatar
I have not seen it before on their site as well but saw it in their show room. Give Terry a call and tell him that Kevin from the site said to hook you up! Well that and regular price should get you one shipped right out.
Kevin
LFD Inc.
Old 09-13-2007, 12:25 AM   #10
70cst
70cst's Avatar
Thanks Rokcrln...
Old 09-13-2007, 12:34 AM   #11
IAFF2407
IAFF2407's Avatar
thanks, I'm out to get one. My truck smalls like a java hut because of all the damn coffee I've spilled.
Al
IAFF2407 is offline   Reply With Quote
Old 09-13-2007, 12:39 AM   #12
Rokcrln
Rokcrln's Avatar
Thanks Rokcrln...
Any time! Here is the part # for the cup holder conversion
05-5400 $55.00
Kevin
LFD Inc.
Old 09-13-2007, 12:42 AM   #13
jfalesi
Junior Member
I bought one like this from GMC Paul's a while back and the instructions indicated that it came from Old Air (or Vintage Air - can't remember which). Haven't installed it yet but it looks pretty much the same.
jfalesi is offline   Reply With Quote
Old 09-13-2007, 06:14 AM   #14
A.P.
Black 72 Chevy
A.P.'s Avatar
Looks good.
72 Chevy, SWB, 350engine, TH400
A.P. is offline   Reply With Quote
Old 09-13-2007, 06:58 PM   #15
xmitsu10
xmitsu10's Avatar
Not to jack this thread, but here is another option from a fellow board member. I made one for mine this summer and love it. Plus it catches the spills too and can hold your cell phone/wallet as well. About $10 for everything (cupholder from Wally World).
http://www.67-72chevytrucks.com/vboa...ghlight=wedgie
71 Cheyenne SWB
xmitsu10 is offline   Reply With Quote
Old 09-14-2007, 10:27 AM   #16
72 longhorn BB
72 longhorn BB's Avatar
Is that ECE cup holder kit made of plastic, or is it real metal fab?
Chuck
1972 C-20 Longhorn
402 BB .030" over (409?), curved HEI,
RV cam, quadrajet, dual 3" exhaust, TH 400 ported w/shift kit
1999 K1500 Suburban (old style)
5.7L Vortec
4L60E
"No matter where you go, ........ there you are"
72 longhorn BB is offline   Reply With Quote
Old 09-14-2007, 02:21 PM   #17
JameslovesJammie
God Bless Mr. T
JameslovesJammie's Avatar
Yup...it's pretty cool! Classic Trucks Magazine did a writeup on it about 6 months ago...but I've never seen anyone actually install one! Thanks for the pics!
Like a midget at a urinal...sometimes you must stay on your toes.
JameslovesJammie is offline   Reply With Quote
Old 09-14-2007, 02:37 PM   #18
Orange
Licensed to Thrill!
Orange's Avatar
Man, as soon as I get my gas tank moved, and get storage behind the seat, then I can quit using my ash tray for all the crap I [can] carry in it, and put one of those in.
My aftermarket air got rid of my glove box so conveniently.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 09-14-2007, 03:16 PM   #19
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I have seen those on their website, excellent mod! It looks like it turned out great!
I always wondered how it would look as a finished product.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-14-2007, 04:04 PM   #20
clay68c10
clay68c10's Avatar
I've got the same one from Old Air Products in Ft Worth and I really like it. It's all metal and the slide mechanism is very solid. Way more useful than the old ashtray ever was.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 09-15-2007, 11:58 PM   #21
Rokcrln
Rokcrln's Avatar
Yep it works great for cans and shorter bottles the large drink cups hit the dash and they are a bit top heavy. It is made of steel and high impact plastic. It is by far as good if not better than the new factory cup holders you get with the new $30K+ trucks.
Kevin
LFD Inc.
Old 09-16-2007, 12:47 PM   #22
rodstored-72
chevy truck fan
rodstored-72's Avatar
kevin,
i am going to order mine on monday. when i call i am going to tell them that kevin from lfd recommended me. i know brothers sells the same kit, but for $58. i have already taken the astray out & started cleaning everything. when i get the package i will return back to this post for more instructions... by the way are the instructions pretty detailed for doing the install??
thanks for the time to post. if i remember & do a good job i will take pics as well.
rodstored-72
rodstored-72 is offline   Reply With Quote
Old 09-16-2007, 04:45 PM   #23
Custom 68
Custom 68's Avatar
now does this require removing one of teh factory AC hoses to the center vent? I thought a few years ago one of them did?
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 09-20-2007, 07:59 PM   #24
muddpile
muddpile's Avatar
I just installed my set of these as well. My bracket had the plastic slides, so I did not even need to trim it. I got mine from Athey's trucks in Jan. 05 (said the invoice). Took my time installing it
muddpile is offline   Reply With Quote
Old 09-26-2007, 09:19 PM   #25
Custom 68
Custom 68's Avatar
ttt
Dave
