How much coil to cut? Please help!
I need to lower the front of my project this afternoon abd I am cutting a coil.Rumor is 1/2 a coil is 1-inch. Please help, Is this true???????
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
Re: How much coil to cut? Please help!
thats what they told me, cause i'm doin the same thing. i got a question though, how do you get your spring off the truck? i have a spring compressor, but i had to ghetto rig a spacer thing to get it to work, and it's still a pain in the butt, is there a better way to get it off?
For the front? Just place a floor jack beneath the lower control arm and remove the lower spindle nut, shock bolt and tie rod end. Apply pressure to the control arm and hit the side of it with a good hammer downward on the control arm. Slowly lower the jack and hit it, allowing the jack to drop a llitle at a time until the compression is off the spring. pretty easy.
Thanks for the info.
#4 | |
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
1/2 coil is generally a half inch every spring is different but 95% of the time it is true, my buddy cut his on his 71 and this rule did work, every 1/2 coil or inch it increases the spring rate by 10%
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap |
ttt for help
when i asked, every1 that replied said 2 inches per coil, thanks for the tip, ill try that... i'll just make sure not to get my face in the way, jorgen : )
Thanks AlienYouth, I appreciate it, guess I'll try it when I get home and swap out the old control arms for the new ones I just recieved.
I have started this. I am going to cut 1 coil (@2") put it back together and drive it, see what it looks like. I am using the procedure in FAQ to drop the lower A Arms. Backing the ball joint nut off and lube it then BFH. Worked for the left side however the right side wont give it up. Any other ideas other than spray A lot of lube and let sit over night??? Sorry I didn't mean to high jack the thread.
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" ![]() |
Did you remove the tie-rods, I have done this before. Hit the crap out of it.
#11 | |
exactly.
#13 |
Find a big a$$ socket that fits over it to sit on the ground and use a really big BFH
#14 |
I have been beating the crap out of the spindle it will not let loose. 4lb sledge and brass drift. What would be the issue of removing the top A-ARM and pulling the spring? Putting everything back together. The top A-ARM did let loose, however I have not removed it yet?
#15 |
Are you changing the ball joints, if so, slowly let down the control arm, remove the spring and castle nut and wallop the ball joint.
I couldn't get mine loose either but since I am changing the parts I nailed the ball joint and it came right out. An YES 1/2 - 1-inch
#16 |
I do not plan on changing my ball joint.
#17 |
Next project: 1970 K10
If you don't want to replace the ball joint, do this. The way I've always done it is to loosen the nut on the lower ball joint, and let the lower control arm hang down with the spring in place. Get a really BFH and snack the spindle right where the ball joint studs sticks in. Don't use a large punch or drift, you will never get the energy needed put on the spindle. The spring pressure will pop the ball joint out after two or three GOOD whacks.
If you want a warm fuzzy when pulling the spring, run a chain through the center of the spring and down through the bottom of the control arm. Then pull the ends together somewhat tight and bolt them together. But I've never seen a need to do it on these trucks, they are fully extended after lowering the control arms a very little bit. When popping a tie rod end, position (or steer) the spindle so that when you apply the really BFH, your blow if directed in a straight line from the outer part of the knuckle (where the rod end fit the spindle) to a imaginary line running from the upper ball joint stud through the lower. The spindle will have less of a chance to want to "turn" when you hit it, thereby taking all the force of the blow where it needs to be. I have yet to need a pickle fork, or heat, or ???? to break free a ball joint, tie rod, idler arm, etc. Even easier than a BFH is a healthy air hammer with a blank punch.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 09-17-2007 at 02:42 PM. |
#18 |
Thank You for the reply!!
#19 |
Self-proclaimed LED man
Sounds like you all need a pickle fork...at least thats what i have heard them called before. Its a forked wedge that you slide in between the ball joint and the a-arm. Helps to separate them.
Justin
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once ![]() Norwood Survivor |
#20 |
Pickle forks can tear the boot on the ball joint. All the wrenching I did in my past life was suspension and alignments. I've never owned or needed a pickle fork.
This is my tie rod/ball joint removal tool. Same thing, but mine is 19 years old! 52 oz dead blow ball peen. ![]() ![]()
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 09-17-2007 at 03:16 PM. |
#21 |
It's a catastrophic success.
![]() Join Date: Jan 2003
One other option.Support the truck, place another jack under the pivot rod on the lower A arm. Remove the two U bolts and lower the assembly, this also saves the balljoints.
The springs have a place to sit in the lower A arm and a place in the cross member. Cutting only half a loop will make the spring sit funny so I recommend cutting complete loops and in line with the old end. |
#22 |
Damn Yankee
Josh- I told you that was crazy....running threaded rod through is an excellent way to release the pressure slowly and minimize the risk of DEATH
#23 |
Who is Josh?
#24 |
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#25 | |
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride ![]() ![]() 54 caddy 62 series 4 door(younger sons ride, aka 54caddy ![]() 70 caddy 2 door, 89 chevy silverado stepside(older sons rides ![]() |
