Old 09-13-2007, 12:54 PM   #1
Zonaman
Zonaman's Avatar
Little help with a "hot starter"
I've noticed that my starter will quit on me after a long drive to the lake, hauling my boat in 100+ temperatures. It'll quit working for a few minutes, then it will turn. That's so far. Since this tends to happen on a boat launch ramp, you can understand my concern! I gather from reading some past postings that it's absorbing too much heat from the headers.
My questions:
  • Is this a temporary condition that a heat sheild will cure or is this casuing permanant damage to the starter?
  • I've also noticed that it will grind occasionally (a few times in the last month). Is this a sign that it's on it's way out?
  • If a new starter is in order, what are your recommendations for a daily driver in the desert?
Thanks!
(PS- I will check to be sure the wiring is in good shape!)
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 09-13-2007, 12:58 PM   #2
AlienYouth
AlienYouth's Avatar
Re: Little help with a "hot starter"
yes, it is causing permanent damage, ive gone through two with my headers, and they would slowly become weaker over time, and then go up in smoke...
if it hasnt become weaker yet, hurry up and get that starter blanket or heat shield before it does...
Picturesss
71 C10 383/TH400
13.65 @ 99... 2.06 60' spinnin :/
AlienYouth is offline   Reply With Quote
Old 09-13-2007, 01:04 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
A remote starter solenoid is supposed to help as well...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 09-13-2007, 01:08 PM   #4
ChevyC102007
ChevyC102007's Avatar
I have the same problem with my truck but I still have the original manifolds and the down pipe is right against the starter (about a quarter of an inch) I cant put a conventional heat shield on due to the lack of space3 but Im going to get a heat blanket for it ASAP since its starting to click occasionally when I try to start the truck after its ran for abit.
If it aint one thing its another.
Oh BTW I noticed when I changed the starter what looked like a conventional pad for a later model starter and NAPA does list such a starter for my truck, would this be an option to stop this since those starters are abit shorter?
"When you were born, you cried and the world rejoiced.
Live your life so that when you die, the world cries and you rejoice."
[Cherokee saying]
2001 Dodge Ram Sport 1500 4x4. (old ride)
1987 GMC V1500 Sierra Classic ("new" ride)
ChevyC102007 is offline   Reply With Quote
Old 09-13-2007, 01:19 PM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
My truck had the same problem. I just finally put a new starter in a couple weeks ago. I also bought a solenoid heat shield and remote starter solenoid. I haven't had time to install either yet....
Also, the starter on my truck was physically small, that may have been some of the problem too? The solenoid and nose cones were the same, but the actual starter was about 30% smaller than the new one I bought. I just bought a replacement starter for a mid 70's truck and it was much bigger. My truck is a mutt, so it probably had some small car starter or something on it?
So far, no "slow starts" even after an hour of driving.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 09-13-2007, 01:31 PM   #6
Dano69c10
Dano69c10's Avatar
Not to hijack, but has anyone installed a F@%d remote solenoid?
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 09-13-2007, 01:36 PM   #7
Sinister
Between Trucks...
Sinister's Avatar
I had one on my '72 LWB. I got the wiring diagram from the Summit kit online, and got the solenoid and wiring from a local parts place. Worked great. I need to put one on the '69 now...
Beat it to fit,
Old 09-13-2007, 01:42 PM   #8
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I have read many posts about this same topic, but when it happened to mine several years ago, I had a heat shield installed. Didn't know how well it would work, but six years later there are no issues. I have headers and am still running the same starter almost 8 years after buying my truck. I didn't have a problem until I replaced my rich-running Edelbrock 1406, with a new Edelbrock 1901 Q-Jet, which ran much leaner causing the hotter-running engine and the heat soak which made starting difficult.
I'd put the heat shield on it, first. I'd let the results of that dictate my next step.
Member Nr. 2770
Old 09-13-2007, 01:50 PM   #9
Bucky71
I also did the Ford remote solenoid. It didn't help, but I think the starter was too far gone. With a new starter there have been know problems except when the flexplate stops at the spot where a tooth is missing.
Bucky71 is offline   Reply With Quote
Old 09-13-2007, 01:55 PM   #10
AlienYouth
AlienYouth's Avatar
ha, my old truck had some worn teeth, but it didnt have a dust cover, so i would just climb under and turn the flexplate a bit : )
Picturesss
71 C10 383/TH400
Old 09-13-2007, 02:04 PM   #11
Mudder
Mudder's Avatar
I would go with the blanket and have thought about using header wrap either on the headers in that area or around the started. That stuff is awesome as far as stopping heat.
Mudder is offline   Reply With Quote
Old 09-13-2007, 04:05 PM   #12
neonlarry
neonlarry's Avatar
Probably the best thing for your situation is to get one of the later model delco permanent magnet starters. They are much smaller(more clearance between header), much much lighter(easier to install) and with the perm magnet the heat does not affect it anywhere near as much as the coil magnet. Plus its a direct bolt in.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-13-2007, 04:26 PM   #13
Sinister
Between Trucks...
Sinister's Avatar
Do you have a part number or application for these starters?
Beat it to fit,
Old 09-13-2007, 04:39 PM   #14
Zonaman
Zonaman's Avatar
Amen!
Old 09-13-2007, 05:57 PM   #15
IAFF2407
IAFF2407's Avatar
had the same problem, with my truck, jeep cherokee and a ford. intermittent starting was always a weak bendix spring. (including the ping/rattle caused by movement of the shaft allowing the gear to hit the flywheel) all cases were fixed by replacing the starter. With my Sierra, the HO motor and headers, I put a high torque starter in, it is half the size of a stock one. thus will not get as hot. going on 2 1/2 years now.
IAFF2407 is offline   Reply With Quote
Old 09-13-2007, 07:14 PM   #16
oldsmobilekindofguy
you could just try using exhaust heat wrap, it doesn't look the best but you could wrap the header in it and i won't get so hot and should save the starter.
1967 c-10 longbox project, check it out in projects
1969 c-10 parts pickup, twisted frame
Daily driver- 1970 Olds delta 88, 2dr., 455, gotta love the big block
oldsmobilekindofguy is offline   Reply With Quote
Old 09-13-2007, 07:15 PM   #17
oldsmobilekindofguy
it works pretty good to cause a friend used it on his motorcycle and it helped a lot
Old 09-13-2007, 08:13 PM   #18
neonlarry
neonlarry's Avatar
I got mine here about 3 yrs ago:
http://superpageshosting.com/4alters...n&catuid=11378
