Old 09-13-2007, 02:12 PM   #1
cerebus
bare block storage
I have a 73' 454 sitting on an engine stand and there's some rust forming on the cylinder walls. Should I be concerned? I won't be touching this block for atleast another year while I finish school and save for a house. Is there a proper way to store a block for long term.
-- Tall, Dark and Handsome... Or so my mother says
-- There is no fate, but the fate we make.
cerebus is offline   Reply With Quote
Old 09-13-2007, 02:17 PM   #2
cdowns
cdowns's Avatar
Re: bare block storage
no need for concern let it rust and by the time you get out of school you'll get a good job and be able to scrap it and buy new
Old 09-13-2007, 02:37 PM   #3
1971K54X4
Member
I always spray bare blocks down with wd-40 and stick them under my work bench. Make sure you get all machined surfaces covered.
Korey
1955 Bel Air 2 door hardtop
1971 Blazer 4x4
1973 Z-28 Prostreet
1971K54X4 is offline   Reply With Quote
Old 09-13-2007, 02:45 PM   #4
71big block
1971 GMC 3/4 ton, 572 CID
71big block's Avatar
I spray them with LPS and put them in a large heavy duty trash bag. I've had blocks sit for 5 years with no rust.
71 GMC 3/4 572 CID,
1988 GMC 1/2
2006 Saturn Vue
"We always have parts left over on a job this size"
71big block is offline   Reply With Quote
Old 09-13-2007, 02:45 PM   #5
Lated
Lated's Avatar
I second the WD-40. I sprayed it on all the machined surfaces of my 350 and then put an engine bag from summit on it. The block had just barely started to rust before I put the WD-40 on it but I haven't noticed any new rust since then and it's been sitting for more than a year and I rubbed the rusty spots with a clean rag after I'd sprayed the block and it all came off. I've heard of people "pickling" their blocks by just leaving them out in the backyard unprotected. Supposedly a thin coat of rust actually protects the metal (but from what) but personally I'd rather just prevent the rust in the first place.
“If you don’t have time to do it right now, how will you ever find time to fix it.” - author unknown
'70 SWB Step-Side (More rust than metal)
Lated is offline   Reply With Quote
Old 09-13-2007, 02:47 PM   #6
BCOWANWHEELS
use a light coat of clean axle grease on all machined surfaces to be safe. double wrap it in trash bags and keep it off the floor best you can. be good for mant years.
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 09-13-2007, 04:21 PM   #7
gotchevys?
gotchevys?'s Avatar
I have also used good clean grease to coat the inside of the cylinders and all machined surfaces. I then just put mine on a shelf with a old towel covering it. Stayed rust free for years.
www.fatdaddieshotrods.com
gotchevys? is offline   Reply With Quote
Old 09-13-2007, 06:16 PM   #8
Scott68-93-97
Scott68-93-97's Avatar
I 3rd the WD40 I have used it storing all motor parts works well, also wrap it up in plastic after coating with the wd
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
Old 09-13-2007, 07:40 PM   #9
cerebus
Thanks for the info guys. I'll spray it with WD-40 and wrap it up.
Old 09-13-2007, 08:00 PM   #10
Lated
Lated's Avatar
Why didn't I think of using garbage bags instead of paying 5 bucks for an engine bag? Oh well, live and learn.
Old 09-13-2007, 08:28 PM   #11
That's why we come here. something that is obvious to one person, gets overlooked by another (that would be me normally )
