I swear......
....that I am sorry for doubting. I have written on here before about some electrical probs. that I have had with the parking lights on the stepside. Sometimes both taillights would blink, sometimes neither when you apply the turn signals. I've read on here b4 about grounding problems and figured no way that will work with my problem, but I tried what you guys said and ran a ground wire from the bolt that holds each taillight onto the bracket to the frame and the whole thing magically worked that instant. Thanks again for the advice and all the info you all have on here.
Re: I swear......
glad you finally got it fixed/// its just plain amazin the amt of time and money wasted changing parts when a piece of 80grit and somtimes a short piece of wire will fix the problem
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: I swear......
Re: I swear......
yup when they do unexplanable things it's a grounding isue
common sense isn't so common anymore |
Designated A-hole!
Re: I swear......
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Re: I swear......
9 out of 10 electrical problems are usually a result of bad grounding.
Mike
Mike Redpath |
its all about the +6 inches
Re: I swear......
I've seen people who have turned wrenches for 30+ years pulling there hair out over bad grounds. Once you understand electrical stuff, and the way it works, it's pretty easy, and you can start to 'read' the faults.
There's only so many things that can go wrong with electrical components, power, wire, switch, load (ie, light, motor etc) and ground. once you realize and understand that, it's cake. Which is why I say the aftermarket harness industry is one step away from being a sham. They are feeding the fear of electronics, and making people NOT learn how to fix/troubleshoot the real problem. There's a time for a new harness, but they are chainged out WAY more often than really needed. Last edited by Longhorn Man; 09-14-2007 at 03:01 PM. |
