Old 09-13-2007, 09:40 PM   #1
Piece of Work
Cultural Infidel
Piece of Work's Avatar
Something odd going on
Something odd happened today on my way home from work. I've been driving this truck every day since March of this year, about 7,000 miles. Never has the temperature gauge worked or moved. I don't believe there is a sending unit. The needle would swing all the way to the right, then all the way to the left, where it has always read. It did this several times, only under acceleration. I think it has to be a short of some kind, any ideas?
-Mark
posted via La-Z-Boy
-Mark
1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold
1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 Also sadly Sold!
It may be that your whole purpose in life is simply to serve as a warning to others.
A man is not complete until he is married -- then he is finished.
Piece of Work is offline   Reply With Quote
Old 09-13-2007, 09:48 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Something odd going on
Look on the drivers side of the engine. Look for a green wire that may or may not be hooked to the sending unit on the head between the first and second exhaust port. The wire is probably sitting on the exhaust and melted. When the wire gets grounded, it'll max the temp guage out.
On the good side, you now know the guage it's self is good, and some of the wire is good!
Old 09-13-2007, 10:23 PM   #3
Piece of Work
Cultural Infidel
Longhorn Man,
It's funny that you mention I "now know the gauge it's self is good". Just last night I was looking on-line for a temp gauge I could install in the dash. Maybe just a sending unit and a little more "good" wire. Thanks for the info on where to look for the problem.
-Mark
posted via La-Z-Boy
-Mark
Old 09-14-2007, 12:35 AM   #4
68K20 x Drill
Sometimes if the engine has been replaced, there is a light sender where there should be a gauge sender, and you get a gauge that rises to about 1/4, then sits rock steady.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 09-14-2007, 02:08 AM   #5
72armyswbtruck
72armyswbtruck's Avatar
Didn't know that!
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 09-14-2007, 10:32 AM   #6
Bucky71
Smile Re: Something odd going on
The wire on mine falls off the sensor really easily. Luckily it hasn't been melted yet.
Bucky71 is offline   Reply With Quote
Old 09-14-2007, 03:13 PM   #7
Longhorn Man
The electrical connectors are different between lights and guages... I can see it happening still (say in an engine swap and just *making it work* kinda situation) but I wouldn't think it would be too common myself.
Bucky, try very lighly crimping the connector on your wire, Ever so slightly. If/when you go too far, use a small flat head screw driver to open it back up, then try again, easier this time.
Old 09-14-2007, 03:44 PM   #8
Bucky71
I'll try that. Thanks.
