Old 09-14-2007, 10:34 AM   #1
Daubs
Daubs's Avatar
Where to find new alternator? (not rebuilt)
Made the mistake of getting a rebuilt alternator from parts store. Headlights go dim, then bright, as do the dashlights. I'm tired of messing with the rebuilt stuff and want a new alternator. Called my GM dealer and they say no longer offered.
So the question is where can I find a new alternator? Not a rebuilt one?
'72 Chevy K-20 Crate 350, SM465, 4.10's
Daubs is offline   Reply With Quote
Old 09-14-2007, 10:41 AM   #2
Andy4639
Old member
Andy4639's Avatar
Re: Where to find new alternator? (not rebuilt)
If it's a orignal one with the external voltage regulator it's more than likely it, not the alternator. If it's been swaped over then you can take it to a good rebuilder and have it fixed.
To buy a new one try Jegs or one of the other supply stores they sale them new, but they are aftermarket unit's.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-14-2007, 11:04 AM   #3
Ace in the hole
You could always do a conversion to a newer style, found this posted elsware on the board- http://www.chevelles.com/techref/tecref14.html
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 09-14-2007, 11:08 AM   #4
jay6891
Car Knocker
jay6891's Avatar
I think the one I have on my truck came off a 80's model trans am 105 amps and no external regulator. Got rid of all them dimming problems.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 09-14-2007, 11:11 AM   #5
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
You probably have a 42 amp alternator. New or used it will do the same thing. Go out and buy a 65 amp or bigger alternator and that should solve your problem. This would also be a good time to convert to an internaly regulated alternator also. We have kits for around $12.95 that convert your wiring over to that. We also have complete harnesses that do not need converting. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 09-14-2007, 11:29 AM   #6
killer71
killer71's Avatar
check this thread out. Good fyi and aftermarket recommendations as well. http://67-72chevytrucks.com/vboard/s...d.php?t=231241 I personally used tuffstuffperformance.com which was a 100amp internal regulator alternator and had great luck with it. Hope this helps!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 09-14-2007, 11:58 AM   #7
cdowns
cdowns's Avatar
new altenators are readily available summit jegs jcwhitney to name a few but like stated with ext regulator thats the way they work and the dimming willpersist even with a new alt and ext regulator
Old 09-14-2007, 12:00 PM   #8
Scott68-93-97
Scott68-93-97's Avatar
Put in a new internal regulated one no harness needed just some simple wiring, if you have questions let me know
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
Old 09-14-2007, 01:46 PM   #9
Daubs
Daubs's Avatar
Good feedback. I'm thinking this alt. is about dead...after I start it squeels like a stuck pig for about first block (I'm guessing it's struggling to charge the battery after the drain of starting).
Headlights and dash lights are really erratic. Sometimes very bright, sometimes, dim as can be. Sometimes they vary based on engine RPM. I'd love to solve this problem.
Stronger alternator?
Change external regulator?
Would rather not rewire the whole truck at this point in time...
Suggestions?
Old 09-14-2007, 02:11 PM   #10
Scott68-93-97
Its only a couple of wires you re-use the positive to the battery and you'll need a test light to find the excite wire (or feild wire) key on, then just jump a wire from the positive on the alt. to the sense wire and your done, external regulators are a waste of money and if you use a stronger one youll keep frying the regulator, plus if you have aftermarket stereo like a sub youl blow them all day
