Old 09-14-2007, 07:22 PM   #1
1983shorty
1983shorty's Avatar
better headlights ?
i posted a question about aftermarket headlights quite awhile ago. cant seem to find it with search. somebody said they had better headlights you can get at napa i think. bluestars or silverstars or something ! cant remember now. going hunting next month and i want to get my lighting up to par. anyone ? for an 83 gmc 1\2 ton.
1983shorty is offline   Reply With Quote
Old 09-14-2007, 07:41 PM   #2
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Re: better headlights ?
Sylvania Silverstar Ultra - bright as hell, you will see everything. Unfortunately my experience with them has been that their life is very short, like 9 months short, and having 4 of those suckers on my car it's like $100 at least once an year. I'm now using Sylvania XtraVisions, they ain't as white and bright as the Silverstars, but they don't burn out as often either. There's another great headlight, GE NightHawk, or at least that's what I've heard about them, never used them myself but I am planning on purchasing a pair for my truck upon one of my next paychecks.
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 09-14-2007, 08:16 PM   #3
1983shorty
1983shorty's Avatar
are all these headlights available at most autoparts stores ?
and how much better are they . i think i have halogen replacements in there now.
Old 09-14-2007, 08:19 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
I purchased my Silverstars at O' Reallys.
piecesparts is offline   Reply With Quote
Old 09-14-2007, 08:24 PM   #5
Pyrotechnic
Pyrotechnic's Avatar
I've read that running headlight relays that feed the headlights with a power cable right from the battery will give you more light even with sealed beams. Never tried it but people seem to be seeing good results.
Pyrotechnic is offline   Reply With Quote
Old 09-14-2007, 08:57 PM   #6
Duro5341
Duro5341's Avatar
I upgraded to the euro light, that has a clear lense, and take H3 bulbs....
I purchased silver stars for it, and i have had them for about 9 months now, no problems...the H3 bulbs will set you back about $30 for the pair
Duro
-1986 K10 LWB, 350 HD,TH400
3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires
All original, second owner truck
-1979 Monte Carlo, 350, 200r4, 3.73 posi
-1987 GT T-top Mustang - slow moving project
Duro5341 is offline   Reply With Quote
Old 09-14-2007, 10:03 PM   #7
Ivan D.
Ivan D.'s Avatar
Duro, my bad experience with the Silverstars have been with their sealed beams, yers being separate bulbs may be cooling off better or something. And yes, relayed harnesses are a great deal of help, plus they reduce the chance of electrical fire cause of the headlight switch too.
Old 09-14-2007, 10:32 PM   #8
Country Cadillac
Country Cadillac's Avatar
how much of the silverstars per headlight? I need to put head lights on bad.
1987 GMC R1500 TBI 350 700R4
Country Cadillac is offline   Reply With Quote
Old 09-14-2007, 10:59 PM   #9
Ivan D.
Ivan D.'s Avatar
For my Lincoln I was paying about $25 per headlight, I use 4x6" sealed beams. Looking at yer avatar picture, that's what you'll be needing too, me thinks.
Old 09-15-2007, 02:20 AM   #10
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
I've got clear lense headlights with the H4 halogen replacement bulbs in them
The bulbs are high out put 90watt low beam/130 watt high beam.
As a precaution to eliminate letting the smoke out of my wiring harness I wired up 2 relays one for the low beam and one for the high beam. After installing the lamps though,I had to re-aim the lights so they wouldn't blind people when I pulled up behind them at a stoplight with the low beams on.
Oh yea, the lenses were $65.00 for the pair and the bulbs were only $12.50 each. white light not blue and I've had them in it for almost 3 yrs without any burn outs.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 09-15-2007, 06:29 AM   #11
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
What gauge wire did ya use for that install?
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
Old 09-15-2007, 11:53 AM   #12
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
I have been running silverstars for more than 3 years now, mine are the sealed beam type in my 80 model, have never had any problems with them what so ever and are much brighter than the originals. I paid like $25 a piece for mine, but well worth it. I bought them at O'Reilly's.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 09-15-2007, 02:11 PM   #13
BLE 'BURBAN
the main lead (fused) from the battery is 12 gauge wire as well as the ground leads. the rest is 14 gauge.
Old 09-16-2007, 08:48 AM   #14
1983shorty
1983shorty's Avatar
i bought the silverstars yest. $25 each at murrays. i need to fix my headlight aimers before i put them in though. the plastic clips for up and down aiming are broken. think i will just weld a nut to a washer and then weld that in place. should be an easy fix.
Old 09-16-2007, 10:27 AM   #15
piecesparts
Whether or not you use the plastic clip or eld in a nut, put some "Anti-Sieze" on the threads, that keeps them from freezing up over the years. My plastic nuts have been in mine for quite some time and the stuff still works well.
Old 09-16-2007, 02:31 PM   #16
84_chevrolet
Truck CRAZY!
84_chevrolet's Avatar
Which aftermarket headlights have u guys had success with? which one gives out the most light? i am wanting to order the euros from lmc just wanting 2 know if it is the best or if anything else is better?
84 Chevrolet stepside, 350 with .60 over pistons, aluminum zr1 heads, doug herbert .500 lift cam, 1.6 roller rockers, elderbrock intake with a 600 holley carb, mated to a 700r4, 208t-case and 4-11 gears,33 goodyear wrangler mtrs
84_chevrolet is offline   Reply With Quote
Old 09-17-2007, 09:59 AM   #17
Duro5341
Duro5341's Avatar
The H3's I have in my truck are standard silver stars, and require the same wattage as stock...I believe it's 55w low beam, and 65 watts high beam. So I am not worried about burning out wires
Or is it 65w - L, and 85w - H....god I forget, been using them for a year no issues
Duro
Old 09-17-2007, 10:02 AM   #18
Duro5341
Duro5341's Avatar
If your ordering Euro's, and it's being driven on the street, stick with regular silverstars, there the same wattage as stock, but alot brighter. I don't even use highbeams anymore. This way cops won't harrass you about your headlights
Duro
Old 09-18-2007, 11:12 PM   #19
84_chevrolet
Truck CRAZY!
So the euro are the way 2 go? even with the bulbs that come with the lights?
Old 09-20-2007, 01:42 PM   #20
BLE 'BURBAN
The standard wattage halogen bulbs are 55w low beam 65 watt high beam.
I have bad night vision due to my very bad nearsightedness. That's why I've gone to the higher wattage bulbs in mine. Now if you want to spread the light out wider as well as farther down the road than stock, I found that the HELLA brand lenses with the diffuser in front of the internal bulb work really great. Unfortunatly for me they are no longer available locally up here. My last set I had got busted up on the hiway from rocks falling off the cliffs.
Old 09-20-2007, 05:55 PM   #21
Duro5341
Duro5341's Avatar
I used the lights that cam with them, and they lasted for about 6 months. Aslong as you stay with the stock wattage, you don't have to mess with your stock wiring, but if you up the wattage, then put in relays and stuff or you'll burn up your headlite switch, and possible wiring
Duro
Old 09-21-2007, 02:32 PM   #22
84_chevrolet
Truck CRAZY!
I ordered the euro headlights from lmc today. I have already upgraded to their heavy duty headlight harness. so when they burn out i will put silverstars in them
