![]() Join Date: Aug 2007
Shoulder Harness set-up
Hello all,
I need to get seat belts in my blazer, I would like to try shoulder harness with the seat belts, so my guess is that I would need to mount the upper part of the belt to a bracket, tab or the side of roll bar or cage. just wondering if I any one is using shoulder belts. Great site and happy to be hear, Thanks you for any response. 7D2N |
The LuvShack Garage
Re: Shoulder Harness set-up
1ST
![]() ![]() 2ND With the top on there is a access point for shoulder belts, obviously with it off a roll bar is pretty much your only option. 3RD ![]() (Please post some pic's of your rig when you get a chance too)
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Thanks for the response,
Didn't know the holes in the side of top above the seat are for that, may go that route don't have a bar installed yet. I'll try to figure out how to get pics and get them on, I'm sure this place is going to be great and I have learned plenty jut reading previous info. I'll have more questions for sure. Thanks again 7D2n |
SKINNY TIRES RULE!
Welcome to the board from Seattle.
Several guys have installed late model seats with integrated belts/shoulder harnesses. There was at least one board member who created some custom brackets to mount shoulder straps to his roll bar. Either way, you'll need to make sure the floor is reinforced at the mounting points (if you have to create custom seat mounts and where the roll bar is bolted down.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
This maybe a dumb question, was there optional shoulder belts from the factory? If so, does anyone have a picture of them? Just curious since the holes are there. Why would Chevy put mounting holes for nothing.
Oh, and welcome to the board.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel Charleston, South Carolina |
SKINNY TIRES RULE!
I believe there was an option, but I've never seen them.
Just somethjing I put together; works top on or off... (UH-60 Blackhawk harness)
'72 K5, known as 'the Fox.' |
I found an ad in Truck Builder Mag for retrofit shoulder harness.
There ad says they have harness for Chevy Truck, they may have something for a Blazer or can make one. May have to call the company, as their website only shows classic mustang. www.ThreePointBelts.com Last edited by 72K5Blazer4x4; 09-16-2007 at 11:24 PM. Reason: forgot link |
I got mine from Wesco Performance. They have alot of options regarding style, colors, & mounting options. Either way you want...race style or more original looking. My opinion: I wouldn't go with the quick links mister.freeze has...Good idea, but I've seen too many of those things pull loose.
Don't have pics of mine on this computer at work, but will try & take some tonight & post tomorrow.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
i used '04 trailblazer seats with integrated belts. i love 'em, but similar seats from a late-model convertible would have been better (they would fold forward better for rear access...)
there are prolly pics around of my install, but couldn't find them on this machine...
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
Here is where I anchored mine. The holes for the lap belt part were existing threaded holes that the eye bolt happened to go right through then I added a big fender washer to the back too. I had to drill a hole for the shoulder belt..this seemed to be a good spot being double floor thick there too (also added fender washer). The seats are out right now to avoid grinding/welding spark burns but you can get the idea.
Thank you all,
I wouldn't have expected that much response, great options but I want to stay pretty much simple lap belt and over shoulder for driver and passenger. If possible mount in the holes in the top. Thanks 7D2N If anyone can help me with posting pics, need help, I struck out again. Last edited by 7D2N; 09-19-2007 at 07:02 PM. |
#13 |
Post Whore
![]() Join Date: Feb 2000
Go to the FAQ section and there are a couple posts listed in the Index to help you figure out how to post pics. If all else fells, pm me and I will get you my e-mail address and you can send them to me and I will get them posted for you.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#14 |
Thanks All,
looks like those set ups work awesome, want to stay pretty simple I'm so looking at some after market belts for close to stock application, can the shoulder mount part of the belt attach to this part of the top? Thanks 7D2N |
#15 |
.....I am working on it.....
In my opinion, a seat belt SHOULD NOT be mounted to fiberglass or even sheet metal. You should have a solid mount.
#16 |
Guys are using S10 belts in these year trucks to get shoulder straps.The factory ones were rare and rarer,now.This means...ka-ching!!Like $500,if you findthem and they`d be your color.I wonder if these vintage seat belt places,like SnakeOyl,could make a set.The originals used seperate buckles,kinda clunky.
#17 |
![]() Join Date: Dec 2002
My 69 Camaro has shoulder belts as an option. So has my parents 70 monte. I have never taken down either set. I would think if you really wanted a set that looked factory. They would be more available in those areas because more were built
