Installing new gas tank tomorrow. Any special tools needed?
I finally found the time to replace my leaking driver side tank. I have a new tank, straps, pump (with new harness) and strainer ready to put in. I have all the basic tools (sockets, impact, wrenches, line wrenches, yadayadayada). Are there any special tools needed for this job?
Re: Installing new gas tank tomarrow. Any special tools needed?
Yes there is ,you need a lot of patiience...lol...if you have basics tools you should be fine,they dont give you alot of room for doing the hoses back up though,that part really sucks
In the Forgotten far North.
![]() Join Date: Jul 2007
Yes you will need a few special tools, they're mostly green in color very hard to come by and easily lost. They're called federal reserve notes and you can use them to hire someone else to do the job for you.
![]() Seriously though if you hook up the hoses & wiring before installing the tank it'll go a lot easier fo you. I found that when you take the old one down it's easier to unbolt the bracket from the frame and take it all out as a unit then swap the brackets & rock guard over to the new tank, leaving the straps a bit loose for final adjustments then slide it under the truck hook up the hoses & wiring then use a floor jack to raise the tank into position and bolt the brackets back to the frame. Remember the ground wire too. lastly hook up the vent hose then the filler neck hose. Gas it up and go!!!
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
Dirteh Kitteh
Don't forget the swimming goggles to keep the dirt and rust out of your eyes!!
Darrin 1955 Willys CJ-5 all original and the oldest CJ-5 on the road. 2001 Dodge Neon (wife's car) 1995 Jeep Grand Cherokee Limited Edition SOLD 1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD 1993 S-10 4X4 Tahoe SOLD ![]() ![]() RIP ESLL |
Re: Installing new gas tank tomorrow. Any special tools needed?
Tank came out easy enough, the pump assembly came out fine, I installed a new pump and strainer, the wiring is recommended to be replaced, but the wiring looked absolutely fine and it was actually thicker guage than what was included with the carter pump
Two minutes after I typed my last message, I was able to find a pair of good brackets for the driver's side tank swb from a Texas truck. $64 including shipping ain't too bad and I didn't have to waste my time tearing one out of another rotted out New England chevy.
While I'm waiting for the brackets. I'd like to dispose the old tank. Who would actually take something like this? Seems like scrap yards don't want them, due to fumes and safety issues. Where do you guys take your old tanks?
Flush it with water, drain it, (to get rid of any remaining fuel and fumesthen take a jigsaw and cut it in half length-wise then your local scrap metal yard should take it with no problems.
