Camaro Club
painting interior parts???
Ok my GMC has blue interior and to me it doesnt fit with how i'm doing the truck so i want to switch it to either black or grey. My question is my dash pad is in perfect shape so would it make since for me to just get a can of that duplicolor interior paint and just paint it. If so has anyone used this paint on a dash pad and how well did it work. i've only used it on hard plastic and it held up very well. Thanks for any info and suggestions
Re: painting interior parts???
ive always found that krylon fusion spray paint works the best on rubber/plasic parts without flaking
here is what there site says Recommended Surfaces: Ceramic/Plaster Glass Hard Vinyl Metal Paper Papier Mache Plastic Wicker Wood ![]() Last edited by 70cstjr; 09-15-2007 at 05:13 PM. |
its all about the +6 inches
I can't remember what the brand is, but I did my dash pad back in 2000, and other than a couple small chops (from packing the cab FULL of crap) it still looks great. I did black, over the med blue.
The headliner still looks perfect, but the door panles live a harder life and don't look too good at all. |
I just did the dash pad on my truck. I used the matte black and it turned out great. However when I painted the vinyl door panels gloss red they turned out very splotchy. I will just have to reupholster those in red vinyl. I think the gloss colors are harder t o use and not get them splotchy. I used the vinyl dye in a can.
SHawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
![]() Join Date: Feb 2004
Just make sure that you do a really good job prepping the surface, ie using a good degreaser on the surface before painting it.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
Camaro Club
When i painted the hard plastic with before i used rubbing alcohol and wiped everything down. it worked really good for removing all the old armoral(sp).
