Old 09-30-2002, 06:24 PM   #1
VDOG
Grand PooBaa Member
VDOG's Avatar
Flowmaster Mufflers
Hello board, its been a while since I was here last.
Anyway, does anyone know what dual offset I should use when I get my Flowmufflers? Im buying them after market, and not at a muffler shop, cost to much. And the guys at the counter are not the brightest either. Thanks
VDOG is offline   Reply With Quote
Old 09-30-2002, 07:02 PM   #2
VDOG
Grand PooBaa Member
VDOG's Avatar
Ok, did I ask a stupid question?
Old 09-30-2002, 07:11 PM   #3
bigjimzlll
bigjimzlll's Avatar
no..im curious about it too
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 09-30-2002, 07:14 PM   #4
cableguy0
what ur asking depends on where ur running the exhaust and where its gonna exit. do some measurin and pick the closest ones
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 09-30-2002, 07:24 PM   #5
VDOG
Grand PooBaa Member
VDOG's Avatar
Ok I understand. Well my plan is to run it out under the rear bumper, considering I have a longbed.
Old 09-30-2002, 07:29 PM   #6
VDOG
Grand PooBaa Member
VDOG's Avatar
This is the reply I got from Brothers Truck Parts when I asked about mufflers.
"You just have to get under your truck and see what will fit properly. It changes due to headers or stock manifolds and if you are running the exhaust inside or outside the frame. "
DOH!!! I forgot that I was running headers. DOH!!!
Old 09-30-2002, 08:18 PM   #7
nate68
my mufflers (not flows but about the same size, maybe alittle smaller. they're terminators, i dont know the dimensons) are under the bed and they are offset in, center out (i think, i have no middle bed section and look at them every day) and the pipes exit behind the tires.
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 09-30-2002, 09:02 PM   #8
Ackattack
Ackattack's Avatar
I have 2 chamber, center/center, but mine comes out in front of the rear tire, so not exactly the same set up.
Ackattack is offline   Reply With Quote
Old 09-30-2002, 09:24 PM   #9
dion
72 Cheyenne
dion's Avatar
I have a Long Bed and mine are just inside the frame from the Headers back, the balance pipe is about a foot back from the Header Collectors and the Flowmasters are right around the Driveshaft and the pipes exit behind the wheels, looks and sound great, 40's with 2.5 pipes.
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 09-30-2002, 09:30 PM   #10
XXL
Seņor Member
XXL's Avatar
Mine is outboard of the frame under the driver's floorboard (really! and on purpose ). It is offset in and center out.
Kenneth
XXL is offline   Reply With Quote
Old 10-07-2002, 07:13 PM   #11
VDOG
Grand PooBaa Member
VDOG's Avatar
Most of your mufflers are just behind the rear wheels.
I want mine to exit on each side of the license plate.
Old 10-07-2002, 07:29 PM   #12
crazy longhorn
Fabricate till you "puke"
My thoughts are , talk with the shop bending the pipe......it will depend on placement,& leaf or coil on the springs. Hell, I can put whatever I want on the longhorn,cause it has leaf springs! the coil sprung trucks dont have the room to play with. another thought,the 2 chamber flows are pretty f***ing loud......I ran a set, &! pulled them after about 2000 mi, & installed a set of Dynomax superturbos. Good luck.....Crazy longhorn
crazy longhorn is offline   Reply With Quote
Old 10-07-2002, 07:34 PM   #13
bigjimzlll
bigjimzlll's Avatar
Hey Crazy Longhorn..do you still have the old flowmasters? Im looking for a used set
Anderson,CA
Old 10-07-2002, 07:54 PM   #14
crazy longhorn
Yes, I still do have the flows......but I promised them to my oldest kid......sorry! i will have anther 'hotrod" to set up, the 89 ranger is runnin a tired 305 CHEV! i think we will do a 331 for that liteweight truck? Crazy AL
