It's the air up here
Floor pan separation
Are the floor pans glued together as factory? Mine are starting to separate, and am not sure if I can bolt them or just align and re-glue? I noticed this from under the truck not from inside the cab.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c ![]() Never drink down stream of the herd! Eric |
![]() Join Date: Feb 2001
Re: Floor pan separation
I would think bolted or spot welded yes...but not glued. A Ford or Dodge might be glued together.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 09-15-2007 at 05:45 PM. |
Well they are definitely not bolted, and all I can see is sealer or glue. No spot welds that are visible any way. What can I do?
![]() Join Date: Sep 2005
bolt it back together for spot weld
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
what you are probably seeing is seam sealer ... it's not a glue, but more of a "caulking" the factory used where two panels joined & spot welded. It's used to help make the panels water proof without welding them solid.
