Old 09-16-2007, 01:04 PM   #1
ProStreet83C10
Drag Racer
ProStreet83C10's Avatar
68 C2500 question
OK guys, is there any companies out there that offer a suspension lift kit for the 67-72 C20/C2500 trucks. My buddy bought a 68 C2500 (2wd) and he is wanting to lift it some. If there is nothing offered for the 2wd trucks is there any companies out there that make a 4wd conversion for the C20/C2500 trucks
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
ProStreet83C10 is offline   Reply With Quote
Old 09-16-2007, 04:31 PM   #2
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Re: 68 C2500 question
None that I know of. How much lift is he looking for? Is his truck a coil rear or the leaf since both were available in '68 on the 3/4 ton. The front will be the problem. I am looking to raise my front about an inch to level the truck. I am considering just machining a spacer for the bottom pocket of the front "a" arm. Let us know what you find.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 09-17-2007, 12:42 AM   #3
ProStreet83C10
Drag Racer
i havent seen the truck much in person so im not sure about coil/leaf rear.
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 09-17-2007, 06:39 AM   #4
I`ve heard the whole A-arm assembly will swap from up through`99s.If that`s true,there are companies like FabTek that make 2wd lifts.
Old 09-17-2007, 08:18 AM   #5
72freak
Rottenwood Garage Member
72freak's Avatar
You can put a body lift on ANYTHING. There are also coil spring spacers, coil spring spreaders, taller coil springs, blocks for the rear.
Any of the above are fine for about 3" without some suspension component changes. Below is a link to a place that has a lot of stuff but I hear the quality is questionable. Most all suspention companies and 4x4 parts companies will have the coil spring spacers that go in the bottom of your spring tray.......I just ordered a 2" coil sprig spacer to raise the front of my dually. You can get the taller springs at the company listed below
www.aimind.com
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 09-30-2007, 08:35 PM   #6
1987_3/4ton_chevy
Cowboy Up
My and my friend brought the truck home today. And waiting for some ideas
1971 chevy k10 *Under the Knife*
Chris Cary
1987_3/4ton_chevy is offline   Reply With Quote
Old 10-09-2007, 10:27 AM   #7
1987_3/4ton_chevy
Cowboy Up
Ok, we re-wired the hole truck to the back of the tail lights and the lights still ain't working, any ideas what else to check? Also, the stick is stuck and feels like it is in Nutral but it ain't, any ideas what to look for with that?
Chris Cary
Old 10-10-2007, 01:20 PM   #8
1987_3/4ton_chevy
Cowboy Up
Shifter problem is solved
Chris Cary
