Old 09-16-2007, 04:47 PM   #1
71 3/4 ton
71 3/4 ton's Avatar
ignition please
i need to figure out how to takeout and put in my new ignition for this set i bought so the ignition will match the doors
71 3/4 ton is offline   Reply With Quote
Old 09-16-2007, 05:22 PM   #2
my70chevyc10
my70chevyc10's Avatar
Re: ignition please
With the key in the off position there is a little hole you stick a paper clip in and pust the button as you turn the key and cylinder counter clock wise or left. Then the bezel should un screw to the left or the bezel comes off first then the key cylinder i cant remember.
my70chevyc10 is offline   Reply With Quote
Old 09-16-2007, 05:30 PM   #3
69ChevyLB
Active Member
69ChevyLB's Avatar
Re: ignition please
It needs to be in the ACC position then turn to the left and remove the cylinder. Reverse to put in new cylinder. The key cylinder needs to be out to unscrew the bezel.
69 C10 LWB Project
47 Cushman Scooter Project
It is better to have loved and lost than to live with a psycho all your life.
69ChevyLB is offline   Reply With Quote
