Old 09-16-2007, 11:04 PM   #1
lyrikz
PITbut
lyrikz's Avatar
Rust pictures. How to repair?
I finally picked up my 1971. I have to say its very low on rust from what i have seen. Here are pics of the worst cases of the rust. Would just like some info on fixing it correctly. When im done painting the car, i dont want to see rust bubbling up 6 years later. Truck will be garaged 95% of the time.
off to pics.
This is the drivers left floor board. It doesnt go all the way through.
This is the drivers side rocker. Only area rusted through.
This is the passenger side floor board. Worst of it. Best way to fix permanetly?
This is the passenger side door. Its nto rusted through, but do i just grind it down, por15, paint and im done? Or do i cut it out.
All advice is apprectiated thank you.
lyrikz is offline   Reply With Quote
Old 09-17-2007, 09:34 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Rust pictures. How to repair?
Yeeoww, nasty lookng stuff at extreme close up. Looks like you took the pics with a microscope.
Hard to see the pics since they're extremely big on my screen, but I would say that the only thing you can do is to cut out the bad and replace with new panels.
Looks like a mig welder and cutoff wheel will be needed. I'm in the process of doing the same on mine...
68gmsee is offline   Reply With Quote
Old 09-17-2007, 09:59 AM   #3
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Yeah, pics are way too close to get a good idea of whats going on. But, from what I can tell, it looks like everything that needs fixed has a replacement panel available. If you can, get some pics a little farther back so we can see the area the rust is in.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-17-2007, 10:02 AM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
It looks like water is getting in the cab from your first pic (the kick panel rust appears to be wet?) The most important thing to do FIRST is determine where the leak is, fix the leak, then fix the rust
It may be coming in from under your dash, I think that's what the last pic is of?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 09-17-2007, 10:12 AM   #5
raggedjim
raggedjim's Avatar
This is kinda like one of those close up pics where you have to guess what it is... Back up a little and give us another chance.
I don't think por-15 will do it for you though, there's gonna be some cutting and welding going on to do it right...
Good luck, Rg
raggedjim is offline   Reply With Quote
Old 09-17-2007, 10:28 AM   #6
lyrikz
PITbut
lyrikz's Avatar
Good luck, Rg
I will take pics further away.. When i drove the vehicle home sunday it was raining and all the sudden water was coming in from under the dash on the passenger side and more water on the drivers side kickpanel. Im thinking its coming from the cowl area somewhere.
I will get more pics at a decent distance and then go from there.
Old 09-17-2007, 11:15 AM   #7
67ChevyRedneck
Look for an old antenna hole on the passenger side. That's usually the culprit there. Driverside, could be the dash leaking (cowl) or the windshield seal.
Jesse James
Project "On a Dime"
Old 09-17-2007, 05:47 PM   #8
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
When I got my 67. it had so much fine dirt built up in the vent, water could just come in the cowl vent opening and run into the cab. I had to dig the packed in dirt out with a screw driver so that I could get water to drain out of the drain hole (rust hole?) in the bottom of the vent.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 09-17-2007, 05:50 PM   #9
lyrikz
PITbut
lyrikz's Avatar
I looked inside teh cowl and there is a TON of **** build up in there. Im basically starting with the rear of the truck and building forward, so im not to worried about that yet.. I will tackle that when i start working on the cab area and the floor boards.
I need to find a sandblaster near by so i can get my rallys blasted and repainted in time for the longhorn WA meet. ahaha.
Old 09-17-2007, 07:33 PM   #10
6470chevy
6470chevy's Avatar
sandblasting will tel you how bad the rust really is instead of how bad it looks
you will be suprised at how thin the metal is in some areas
70 lwb (my work in progress)
64 biscayne 250 I6 (5 year old son's)
68 galaxie 500 fastback 390bb (6 year old son's)
looking for newborn daughter's (???)
6470chevy is offline   Reply With Quote
Old 09-17-2007, 08:43 PM   #11
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
You do need to remove the cowl panel and clean the area out.The rust will continue as long as the area holds water.Its about 6-7 screws and 4-6 bolts to remove it.Many of the vendors sell screens to put under the cowl panel to prevent the buildup of debris in there.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-17-2007, 11:33 PM   #12
wibilly
wibilly's Avatar
i would think in your area it would be easier faster and cheaper to replace the cab. that one looks like it came from here
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 09-17-2007, 11:37 PM   #13
lyrikz
PITbut
lyrikz's Avatar
Replace the cab? Its one of the cleanest and rust free i have seen. ahaha.. There is one area tha tis rust through.. That other stuff is surface. I will get some other pics so you can see how small the rust areas are. I just want to know if you have rust do you have to cut it out to be done 100% with it?? I just want to do this right and once.
replace the cab. ahah..
