09-17-2007, 03:37 PM | #1 |
Frizzle's Inner Fender Mod
I mentioned this mod in another thread so here it is. I'm not done yet, but I'll update this thread as I go...
I want to tuck more wheel but I don't want it to look like I just welded some trailer fenders to the inside of my front fenders. Though I've seen that done and finished off nicely, I want my inners to be "stock looking" to the casual observer. I also want to be able to use the stock hood hinges. Since I have a 68 clip that's going on Tubby I started work on those fenders. First I moved the arch (provision for inners) up 1" by sectioning the inner structure of the fenders as follows: And the other side: |
09-17-2007, 03:42 PM | #2 |
Re: Frizzle's Inner Fender Mod
Here's what the outer part of the stock inners (area most likely to rub) look like on the sectioned fenders:
...and here's what will be there now: Comparison of old v. new: |
09-17-2007, 03:46 PM | #3 |
Backing:
09-17-2007, 03:54 PM | #4 |
The plan is to make a few relief cuts in the stock inners allowing me to raise them enough to meet up with the new outer sections. I will have to get rid of the aft "peak" (two peaks per side on stock inners with bolts from the bottom). By doing so I'll gain a lot of room for the stock hinges, which may still need to be shaved a bit, but I should be able to use all 3 hinge bolts.
I'll figure out how/where to cut the existing inners by bolting these on and going from there. |
09-17-2007, 04:18 PM | #5 |
The LuvShack Garage
Simply Amazing
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
09-17-2007, 04:45 PM | #6 |
You are the man
09-17-2007, 05:25 PM | #7 |
Too many trucks? Nah...
Your whole Burb project has been nothing short of fantastic. Great attention to the whole thing.
09-17-2007, 07:19 PM | #8 |
Looks real good. gonna do the same thing to my 86. Why not weld the bottom too instead of bolting them up or are you?
09-17-2007, 08:49 PM | #9 |
A guy with a truck
Stole my idea... Looks good though
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
09-17-2007, 10:18 PM | #10 |
"1972 C5"
You are a ninja.
09-17-2007, 11:40 PM | #11 |
Thanks guys. I am not welding these to the fenders because I'm welding them to the existing inners (after slight modification). That way the whole inner fender (new+old) will be one unit that bolts to the fenders like factory, just a little roomier. Don't worry I'll use nice hardware
09-18-2007, 07:56 PM | #12 |
your a genesis frizzle fry no doubt about it
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN 62 HARDTOP NOVA 65 CHEVROLET BB LWB FLEETSIDE 90 CHEVROLET EXTRA CAB CHEVY ONLY - NZ Chapter http://67-72chevytrucks.com/vboard/s...d.php?t=137984 |
09-18-2007, 11:56 PM | #13 |
Commander Taco Bello
great write up so far.
that first piece of new metal for the inner... is that a trailer wheel well trimmed down? if so, what size did you get for that radius? |
09-19-2007, 04:51 AM | #14 |
:( BYEBYE :(
looking good, i plan on doing full tubs this winter, ill have to make a lil build page too, i cant wait to see the end result
09-19-2007, 11:20 AM | #15 |
'Preciate the comments. I did use a trailer fender there. I bought them from a site that I've lost the link to but the demensions match this: 355480 9" 32" 15.25" 1",90° BACK 16GA.
09-19-2007, 02:04 PM | #16 |
Tot Roddin'
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
09-20-2007, 02:46 PM | #17 |
WTB this ad
Looks like one of the best inner fender jobs I've seen! Looks like it's going to turn out real clean.
09-20-2007, 04:57 PM | #18 |
Thanks guys! It should be pretty stealthy when done, and you can see how much extra tuckage it'll have.
I just ordered a 355480 9" x32"x15.25" for the other side and two 355700 13" x36"x20" for the rear from KMT. I'm really hoping they're not galvanized It might be a while before I can weld the new tub sections I made to the existing inners because I have to get the entire 68 clip ready to go before I can commit to changing the shape of the inners. But that's a high priority at this point! |
09-20-2007, 11:35 PM | #19 |
Got one side all welded up and smoothed out. Filled the extra holes while I was at it.
09-21-2007, 07:34 PM | #20 |
lil more progress...
09-24-2007, 11:45 AM | #21 |
F.A.S.T. president
That’s very cool, but I would have done them differently.
I would have had you do them on my fenders instead of yours great job
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" Last edited by jamis; 09-24-2007 at 11:45 AM. |
09-25-2007, 05:23 PM | #22 |
Thanks Jamis
Just got my order in from KMT Wow that was fast! I got one more 9"x32"15.25" (355480) for the front and two 13"x36"x20" (355700) for the rear. Check these babies out The rear tubs are different on Burbs v. Trucks as you can see. But they still curve in as you move up from the fender lip. I'll make the new tubs vertical there so I can gain some tire width. 13" trailer fenders will be perfect: Last edited by Frizzle Fry; 09-25-2007 at 05:25 PM. |
09-25-2007, 06:00 PM | #23 |
there going to look sweet Mike
09-26-2007, 02:44 AM | #24 |
mike,you are a fabracation freak,i wish i had 1/3 of your skills and vision looks killer cant wait to see it done,Danny
09-26-2007, 07:05 PM | #25 |
I dun gradjiated collij!!!
HMMMM I wonder where that Visa-Vis marker came from....and those cool ass Patriot safety glasses??????
seriously though, 'Burbs lookin good, and it was good seeing ya today......Bill
Built NOT Bought. Viper Red 1971 LWB C10 355 Vortec W/700R4 4/5 drop AKA Screamin' You are missed!
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! |
