09-17-2007, 05:43 PM | #1 |
Aluminum radiator
I need some help. I want to try to find an aluminum radiator that will be the easiest install. The truck is a 71 SWB. What companies are good for this? The cheaper the better. Will be buying an electric fan through Old Air for it this week, but still need to find an aluminum radiator. It is a 350 motor with less than 400hp.... suggestions?
09-17-2007, 06:00 PM | #2 |
Re: Aluminum radiator
The 73-79 Chevy truck radiator's listed are the same and will fit, the only change you will need to do is put a angled bottom hose connector on in place of the straight that they come with.
I hope this helps, as these are cheaper and easier to find. Or if you run accross one of these at a swap meet, etc...
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 09-17-2007 at 09:55 PM. |
09-17-2007, 06:18 PM | #3 |
If you search "chevy aluminum radiator" on ebay, there is a place that sells direct bolt ins for around $400. I would post a link but I'm computer illiterate.
1970 SWB Build |
09-18-2007, 12:50 AM | #4 |
thanks JMking9.. I think I found one for less than $200. plus shipping. Not sure about these ebay stores, but hopefully it will work out... appreciate the help.
11-03-2007, 10:01 PM | #5 |
MI '69
I just bought one.... it fits decently except for the right top mount. It doesn't clear the rad fill and I had to modify the mounting bracket. I havn't run the engine yet with it so I can't speak for the cooling ability, but the fit isn't great, but you can "make it work"... i'll post some pictures probably next week of my progress in a seperate thread...
one other thing is that its pretty fragile. Much more so than the standard rad.
1967 Chevy (Project Frankenstein) 1973 K5 Blazer |
11-03-2007, 11:17 PM | #6 |
its all about the +6 inches
if you only have 400 horses... what's the big deal in getting an alluminum rad? The advantages are minimal, and in a low power engine, there are no real advantages. just a rad that is more fragile, and more expensive to repair.
11-04-2007, 06:55 AM | #7 |
WTB this ad
Member 71see10 just installed an aluminum radiator that he got from ebay. I'm sure you could PM him and talk him in to posting up some pics.
11-04-2007, 08:15 AM | #8 |
MI '69
Thanks for the info... I got mine mainy for the look and b/c it was a bit cheaper. I'm not gonna be driving my truck everyday, so I figured wear and tear would be minimal.
Thanks for the info see ten.
11-04-2007, 08:39 AM | #9 |
At what HP should you upgrade to aluminum?
11-04-2007, 04:02 PM | #10 |
when it won't stay cool anymore due to the rad and not old/defective parts.
11-04-2007, 04:52 PM | #11 |
Check this one out http://cgi.ebay.com/ebaymotors/ALL-A...QQcmdZViewItem
and if I would have known about this before I purchased my 4 core replacement for $205 I would have bought it
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap Last edited by Scott68-93-97; 11-04-2007 at 04:53 PM. |
11-05-2007, 09:12 PM | #12 |
MI '69
Yah, thats the one I bought... doesn't fit like it says it will... See my post above for more info...
