Old 09-17-2007, 05:58 PM   #1
Ace in the hole
3 speed to 4 speed on a 4wd
I am working on my k20 with three on the tree. I also have a 4 speed transmission from a c20. What all is needed to swap the 4 speed into the truck to get rid of the column shift?
Look like it will not mate right up to the x-fer case shift housing.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 09-17-2007, 08:56 PM   #2
Re: 3 speed to 4 speed on a 4wd
Different adaptor/pedestal.
Old 09-17-2007, 10:17 PM   #3
Ace in the hole
Ya, I was afraid of that. Just another part to hunt down
Old 09-18-2007, 12:06 AM   #4
72 CustomCamper
huh ???
72 CustomCamper's Avatar
The C/20 trans will be a 2 wheel drive trans. You might have a length issue with the 4spd's output shaft...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 09-18-2007, 03:02 AM   #5
68K20 x Drill
I think the 2wd tranny has more output splines as well.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 09-18-2007, 04:17 AM   #6
earl87gta
earl87gta's Avatar
if you have a long wheel base switch to a divorced transfer case it makes life easier and will let you use what ever trans you want to use.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 09-18-2007, 06:25 AM   #7
Yeah,that^^^.Gives you a better front shaft angle,as well.
Old 09-18-2007, 12:17 PM   #8
Ace in the hole
options, options. I could also tear apart the trany and put in the right output shaft.
