Active Member
![]() Join Date: Jul 2007
Finishing out a tailgate help...
What are you all using to fill in the small dents on your tailgates?
I am going to try to fix my GMC tailgate and noticed it has several small dings on the inside that I would like to smooth out. I feel Bondo may be be too soft for this. I used a filler that my brother in law gave me once that was absolutely awesome. It was used on helicopters and was military type stuff. It dried as hard as metal and worked great on a tailgate I fixed some years ago. The activator (catalyst?) dried up on me and I never knew what it was. It just had a military number on it. |
Re: Finishing out a tailgate help...
i don't know how big your dings are but mabey some sort of epoxy such as jb weld. i didn't fix any of them inside my bed because it's a truck bed and truck beds get dinged up. one less thing to wory about
common sense isn't so common anymore |
![]() Join Date: Mar 2007
I am a supply sergeant in the US Army. If you get me the numbers off of the can, I may be able to at least get you a manufacturer or some other info. Any number off of the can will help, but a number in the following format would be best: xxxx-xx-xxx-xxxx.
I have a radical idea!
If you can't find the stuff you had, I'd recommend Evercoat's Rage Gold body filler. It is about $40/gal, but it is so much better than regular filler. It is the easiest to work filler I've ever used, and air bubbles are about 95% non-existant.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#5 | |
Active Member
Travis, sorry, but I threw the stuff away years ago. It was a half of a can and when the catalys dried up I dumped it. I will look into the epoxy/JB Weld first since they're mostly small dings and see what happens (dont know why I didn't think of this). Did a quick search on the Evercoat body filler. Looks interesting. I may have to try some. However, if I'm lucky, I may come across a good used one. I will be going up to Oklahoma soon to visit my daughter. I heard there were a few trucks to look at over there. |
Junior Member
Years ago when I use to do a lot of boating and repairs I got a product from a place that had boat supplies and it dried hard as rock, it wass called Marine-Tex.
I am not sure if it is still made, but a boat place would be a place to look. Danny -Southeast Missouri |
Why Not Use Kitty Hair.resin With Fibreglass Already In It? Works Like Bondo But Much Tougher.
72 2wd lwb cheyenne super youngest son.green/white 72 2wd lwb cheyenne super oldest son.green/white 71 4wd 3/4 cheyenne super frame off manderin copper / white 4 inch lift. FINALLY DONE / SOLD 72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856 |
member #16
![]() Join Date: Dec 1999
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Official Site Guitar Shredder
use a product called duraglass.... imo i would try to pull out the dents as much as you can before any filler work first...., Ever coat products are great , and if used right bondo is a great filler
![]() Join Date: Jan 2005
If you are in my part of Oklahoma come by and look thru my parts.
68 Short Stepside C-10 69 SWB C-10 70 Flatbed C-20 70 LWB C-20 BB402 70 LWB C-10 CST 70 LWB C-10 CST 71 Short Stepside Cheyenne C-10 72 LWB C-10 72 Blazer 4x4 4spd 95 Jeep Cherokee 4x4 |
