yes, i do
so while i'm hear in fallon, nv, so far away from my truck, i'm thinking of stuff that i wanna do to it. so now my question is, how hard is it to change from the old rollerball bar linkage to the newer cable style throttle linkage and how much would i be looking into for parts and how difficult this can possibly be?? when i put my carb spacer in it raised my throttle bar in the cab so much that i can't use the oem pedal any more. so for those of you who have done this before lemme know.
Re: throttle linkage swap
Everyone here suggest LOKAR, but I need some pics so see how it will work?
Junior Member
I used a pedal assembly and cable from a 87 suburban only a little fab nessary
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome." |
You should try a search on this..or maybe check the next page...
http://67-72chevytrucks.com/vboard/s...d.php?t=258577
64 Panel Rebuild Pics Clutch Replacement and Borg Warner T10 Trans Rebuild 64 Panel 1/2 Ton 350cubes/400hp BorgWarner t-10 3:73 Auburn Posi |
