09-17-2007, 09:34 PM | #1 |
1 ton Brakes
I have good proof to believe one of the wheel cylinders on my 1-ton is leaking. So I went to remove the rear drums tonight and noticed that the brake drums don't look like they "slide" off as in a typical vehicle.
I need to know, do I need to remove the axle piece on the end held on by the 8 or so bolts to get the drum off, or does the drum actually slide off the end..... I'm trying to get it inspected soon to take it on a annual camping trip in the next few weeks (the big flat bed should do good at hauling the firewood and supplies) and need to get this done. |
09-17-2007, 09:40 PM | #2 |
Re: 1 ton Brakes
You have to take the axle out. then there is a nut and lockwasher that need to come off. Then you can slide the drum and hub assembly off. About the same setup as a disc brake rotor on a bigger scale.
Be careful its pretty heavy!
68 GMC 64 1/2 Mustang convert A bachelor's life is no life for a single man." - Samuel Goldwyn |
09-17-2007, 09:48 PM | #3 |
its all about the +6 inches
Re: 1 ton Brakes
And take that cylinder with you looking for a replacement... and double check what ever they give you.
i can't speak for the daul rear wheel trucks... but my single rear wheel one ton was a total bear to locate brake cylinders. Heck, they were only able to locate 3. |
09-17-2007, 10:24 PM | #4 |
Re: 1 ton Brakes
Alright, so does the whole axle shaft come out, or just that outer housing??
09-17-2007, 10:57 PM | #5 | |
I have a radical idea!
Re: 1 ton Brakes
http://www.man-a-fre.com/explodedvie...ar.htm#housing
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 09-17-2007 at 10:58 PM. |
09-18-2007, 02:11 AM | #6 |
Re: 1 ton Brakes
Assuming it is a ONE TON truck, after you remove the eight bolts and pull the axle shaft from the housing, and depending on the weight rating of that rear axle assembly, most likely you will find 1. a lock nut to be removed (should use the correct tool - circular wrench with teeth to fit the slots on the nut (drive this wrench with a socket drive); 2. behind that lock nut a lock ring with tabs that have been bent dowm to keep that lock nut from turning loose - need to straighten those outward to remove #1; then an inner nut that looks just like #1, but which is used to torque the axle bearing fit (use the same tool to remove it); behind that nut a thrust washer that seats on a bearing. If you do not have access to the round wrench, it is possible to remove the nuts with a punch or screwdriver to move them CC - but not recommended, especially due to assembly process.
Once all of the above is removed, the drum will slide off the spindle. Bearings will be retained inside the drum. Make sure that you check the seal on the inner side of the drum - it may be leaking gear oil (as a matter of fact, the leaking fluid you are seeing may be gear oil and not brake fluid - eye and smell test should tell you). Once leak has been corrected, assemble in reverse sequence, but the torque (and possibly subsequent back off) of that inner nut should be to specs shown in service manual according to type/weight rating of the rear end. Outer nut torque not as critical, and make sure you lock that outer nut down with those tabs on the lock ring (get a new ring if you can). Depending on how soaked they are, brake shoes probably need to be cleaned throroughly - and maybe replaced if the surface is scuffed/damaged. LMK if you need further info. CCCC
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp Last edited by CCCC; 09-18-2007 at 02:13 AM. Reason: needed further note |
