Old 09-17-2007, 11:00 PM   #1
69gmc292
Belltech Lowering Leafs
I was wondering if any one has pictures of a lowered chevy or gmc with 4 inch drop leafs. I was also wanting to know if it changes the useabilty of the truck. I use my truck for work as well as fun but i hardly ever really load my truck but would like to keep that option open just in case.
69gmc292 is offline   Reply With Quote
Old 09-18-2007, 10:15 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Belltech Lowering Leafs
ttt..
Me too...
I looked at buying some dropped leaf springs once but backed off and basically just removed the "recommended" leaves from mine to lower it slightly (app 2-3 inchses). I removed a coil from the front spring also.
Since I didn't haul in it, I couldn't tell much diffrence in the ride. The stance was helped though. Gave it a slight rake.
68gmsee is offline   Reply With Quote
Old 09-18-2007, 04:19 PM   #3
Primered_69
Primered_69's Avatar
If you want to use it for work. You could always get some air bags for towing and pump it up a little before you load it up.
Also a C notch can be done.
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 09-18-2007, 04:23 PM   #4
Primered_69
look at this thread
http://67-72chevytrucks.com/vboard/s...ight=leaf+bags
