Old 09-18-2007, 01:20 AM   #1
camarossrulz
GMC and Chevy Fenders
is there a difference in the gmc and chevy fenders? I have heard that if you change grilles that you have to change fenders also.
1972 C-10 short bed, 2wd, 350(ls1 coming soon)
1969 camaro ss, 496 stoker, 4sp
2009 crew cab,duramax 2500hd 4x4, lifted (sold)
2008 Daytona Charger, Hemi Orange, 07 C6 Z06
2005 suburban, 2002 grand prix gt
2005 grizzly, 2004 R1
camarossrulz is offline   Reply With Quote
Old 09-18-2007, 01:41 AM   #2
brak
brak's Avatar
Re: GMC and Chevy Fenders
I found this out the hard way...
It really depends which grille you want to switch to...
67-68 are the same for both chev & GMC (68 obviously sporting the addition of side markers).
in 69 chev changed the fender design, but GMC maintained the 68 style.
Another factor in swapping from chev to GMC grille (or vice versa) would be the radiator support. the headlight mounting is different due to the fact that the gmc has dual headlights.
a few members have modified their support, and maybe they will chime in
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 09-18-2007, 01:46 AM   #3
short69
short69's Avatar
as far as I know..
'67... same for gmc and chevy
'68 chevy also fits 68-72 gmc
69-72 chevy fits only chevy
so if you have a 69-72 chevy and wanted to go with the 67-68 grill you would have to get new fenders to go with it.
69 shorty w/ 67 front clip
short69 is offline   Reply With Quote
Old 09-18-2007, 08:40 AM   #4
Huck
Huck's Avatar
AS stated the fenders are different depending on year and logo--GMC / Chev. BUT, there are a lot of other differences that need to match up for correct setup: the hood latch and grill to rad support is different from year to year----, some require trim on fenders---, some require trim on hood leading edge, some have different radiator supports ie dual buckets for GMC, GMC has an upper bar trim above the grill etc. Better take the time to know just what you are trying to do or be prepared to fabricate ~~!!
Huck is offline   Reply With Quote
Old 09-18-2007, 06:22 PM   #5
camarossrulz
well I have a 70 gmc 3/4. it has the gmc grille but my friend said it has chevy fenders. the hood does have a chevy bowtie on it. I was thinking if they are chevy fenders and hood then I would change the gmc grille to a chevy. but it may be a bigger job than I want to get into.
Old 09-18-2007, 07:34 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You'd have to swap out everything on your front clip except the hood, hinges, and inner fenders.
Old 09-18-2007, 08:36 PM   #7
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Arrow Re: GMC and Chevy Fenders
I personally did this on a 67 GMC and the only thing I had to do was remove the GMC grill and reinstall the chevy grill , the radiator support had an extra tab to hold the extra headlight bucket I just removed the tab one on each side inboard and left the outboard tabs to hold the chevy headlight bucket's , I will assume that this will apply to 67 68 truck's for sure can't tell you about 69 up ?
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 09-18-2007, 09:51 PM   #8
71swb4x4
71swb4x4's Avatar
A lot of what everyone is telling is correct to a point. We really need to know what year of Chevy grille you want to swap in in order to give the correct answer.
When people tell you that the stock GMC fenders work for a Chevy grille they are assuming you want to install a 67/68 Chevy grille.
If you post a picture of the front of the fenders where the grille meets it we can tell you if they are the GMC fenders or if someone swapped them out to the 69-72 Chevy fenders.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-18-2007, 10:35 PM   #9
camarossrulz
I will post some pics soon as I can. I was thinking about a 70 chevy grille since it is a 70 model but I will probably leave it alone. but something doesnt look right. may be because it has checy fenders with the gmc grille. I will get some pics up
